10-25-2013, 12:56 PM | #1 |
Junior Member
62 stock exhaust location?
Can someone describe or post pictures of the stock 62 exhaust starting from the exhaust manifolds back to the muffler(s)? I can't seem to find a clear path without running into the Torsion bars and cross-member. Seems they need to run outside of the frame rails, but how does it get there without going under the torsion bars? Does the down-pipe quickly turn outward into the front wheel well to get there? (probably not)
_______________________________________ 62 SWB BBW (under construction) 86 Vette Convertible |
10-25-2013, 02:51 PM | #2 |
Re: 62 stock exhaust location?
Are you wanting full on stock or looking for dual set up? Check my build page and cardomain where the shop put my duals. The layout is about the same short of y-pipe. Get a hold of the big yellow book for our trucks. It has pretty much all info.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
10-25-2013, 03:02 PM | #3 |
Junior Member
I was wanting Duals - but to tuck the pipes up as much as possible. Now I see how to do it. Your pic shows it well http://carphotos.cardomain.com/ride_...4006_large.jpg
Thanks!
