Old 10-25-2013, 02:53 PM   #1
Scott>72-GMC
Scott>72-GMC's Avatar
Fuel line diagram?
Hey guys. I'm in search of how my fuel lines need to be ran I have a 3/4 ton 72 gmc. So there is no charcoal canister it had saddle tanks I'm not using them at this time just the in cab tank the lines running out of the tank are good I just need to know between them to the fuel pump what I need. Weather soft or hard line
72 GMC super custom.
Scott>72-GMC is offline   Reply With Quote
Old 10-25-2013, 02:59 PM   #2
71K20chevy
71K20chevy's Avatar
Re: Fuel line diagram?
Mine's got a piece of rubber line coming off of the barb coming out of the floor (it's a good idea to use rubber there due to the frame flexing), that runs into a hard line inside the frame that runs to the pump, another hard line (with fuel filter) running to the carb.
Oh and try not to use rubber line when not necessary, and please do not under any circumstances use the plastic or glass filters. I've heard and seen a lot of them that break, burning the vehicle to the ground.
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 10-25-2013, 03:41 PM   #3
Scott>72-GMC
Right before the pump is there a section of rubber? That's what is on my pump small section of rubber running into hard line that runs along the frame under the cab. Just can't see under the cab myself to see what goes on from there
Old 10-25-2013, 04:25 PM   #4
71K20chevy
71K20chevy's Avatar
Just checked mine, these is a small rubber piece running from the fram hardline to the fuel pump.
71 K20
64 GMC mud truck
Old 10-25-2013, 04:32 PM   #5
Scott>72-GMC
Awesome. What would you say the total ft of rubber hose is?
Also How is your vent ran. Or is the second line from the tank through the floor a return line? Sorry for the lack of knowledge on this
Old 10-25-2013, 05:55 PM   #6
John Pasinski
John Pasinski's Avatar
I have a '72 1 ton BB. Neoprene rubber from floor under the cab, to the hardline which then runs along the frame to another neoprene section which connects to the pump. One piece hardline from pump to carb connected to the in carb filter. Less than 18" total neoprene. The rubber allows for cab as well as engine movement.
A man's thoughts devise his ways; but it's GOD that directs his steps.
John Pasinski is offline   Reply With Quote
Old 10-25-2013, 06:05 PM   #7
Scott>72-GMC
Thanks exactly what I needed
Old 10-25-2013, 06:59 PM   #8
71K20chevy
71K20chevy's Avatar
Looks like your first Q was answered, I was going to say 2 ft.
As far as the vent goes, I can't help you, as mine is a 3/4 ton and 3/4's didn't get the EEC.
71 K20
64 GMC mud truck
Old 10-25-2013, 07:03 PM   #9
Scott>72-GMC
That's what I was just researching and have found 3/4 tons had no vent line so... I'm guessing a return line?
Old 10-25-2013, 07:26 PM   #10
71K20chevy
71K20chevy's Avatar
Mine doesn't have one.
71 K20
64 GMC mud truck
Old 10-25-2013, 07:57 PM   #11
Scott>72-GMC
I can't think why I have two lines going to my tank Hmmmm. Both go through the same wole in the cab floor
