Motor swap
Hello Gang,
I am new to this board and am really glad to be in with a good resoursfull bunch. I have a 1972 C20 really straight, however the 402 although it runs well, the valve seats are toast from unleaded fuel. The truck gets 4 MPG on a good day. I bought a 350 HP 350 Vortec crate motor, and although I know most want to go the other way from small block to big block, I am looking for any pitfalls that I may find. My info reflects that the motor mount should bolt up. I understand the motor will sit a little lower. Will the Trans cross member fit? Then how about the drive line length? Next and right now my worry is Air cond mounts (passenger side) and Alternator with power steering pump mounts. Long or short water pump? I am going with a canister style steering pump to keep it clean. Any ideas. I'm looking for a clean install,and the motor is built and mostly ready. TinTop |
Re: Motor swap
Here is a look
Re: Motor swap
Very clean truck and motor! Have you considered a March pulley set up? That would pretty much cover all of your bases for the motor. As far as bolting in, you may need sbc motor mounts. However, those are cheap and easy to find. As far as bolting right up to everything else, it should go pretty smooth. What trans are you running?
Re: Motor swap
The trany is a turbo 400. All original. Great wood bed, Stock interior.
