Old 10-25-2013, 05:43 PM   #1
Gene
Gene's Avatar
Skyjacker softride new springs squeak
Not many miles at all on these new springs and the drivers rear set are squeaky as a mutha. I sprayed them down with WD to figure out the area where squeak was coming from. I'm wondering if there's a pad or something missing from this particular spring pack? I looked at the others but they all look the same.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
Old 10-25-2013, 05:59 PM   #2
dieseldawg142
dieseldawg142's Avatar
Re: Skyjacker softride new springs squeak
were your spring bushings greased up before install?
weird you have squeakyness, my skyjackers have never made noise.
maybe try some teflon spring pads
http://www.jackit.com/suspension-par...wear-pads.html
dieseldawg142 is offline   Reply With Quote
Old 10-25-2013, 06:49 PM   #3
vectorit
What?
vectorit's Avatar
Are you sure it's the springs themselves?
Typically what makes the noise, is the poly bushings that make the squeaks.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 10-25-2013, 06:50 PM   #4
Gene
Gene's Avatar
Yes, I greased the bolts and bushings before install.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
