Old 10-26-2013, 10:08 AM   #1
Kennuck
Kennuck's Avatar
Anyone replace foam on bench seat?
I have a 1970 C10 with the spring suspension seat and I would like to replace it with the full depth foam cushion. Has anyone ever converted their spring suspension seat to full foam. LMC and others sell the foam but I'm not sure what the differences are in the seat frame.
Kennuck is offline   Reply With Quote
Old 10-26-2013, 10:41 AM   #2
Mister-B
Re: Anyone replace foam on bench seat?
Not sure what you mean. The stock bench seats have rows of flat springs with foam on top of that. If you remove the springs, there's no bottom to the seat for the foam to rest on, and you'll fall through
Mister-B is offline   Reply With Quote
Old 10-26-2013, 11:47 AM   #3
WIDESIDE72
WIDESIDE72's Avatar
The two seats are different. YOu need a frame designed for full foam. That's why they usually bring a little more money than a spring seat.
WIDESIDE72 is offline   Reply With Quote
Old 10-26-2013, 12:01 PM   #4
MusicMan70
MusicMan70's Avatar
Yes there is a difference in the seat spring it self that determines full foam vs. standard. Please excuse the photo quality
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 10-26-2013, 01:57 PM   #5
Lattimer
Lattimer's Avatar
From the photos I have looked at, I think the frames are the same, if not very very close. The difference appears to be in the type of springs used. The flat zig-zag springs make up the bottom of the full foam bench, vs. the curved springs in the regular seat.
That being said, you would probably be better off finding a junked full foam seat and rehabbing it.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 10-26-2013, 07:09 PM   #6
Kennuck
Kennuck's Avatar
Thanks for the replies guys. Musicmans post clears it up considerably. The way I look at it any seat 43 years old is going to need some refurbishing, so maybe I will order the full foam cushion and see if I can make it work. I don't mind having to do some fabrication so I can probably do something to make it work.
Old 10-26-2013, 07:47 PM   #7
Mister-B
There's a guy on here thats maybe 5'9/10, and he complained that after replacing his foam, his head was up near the roof lol. Just be prepared to shave some off if need be
Old 10-26-2013, 08:01 PM   #8
Kennuck
Kennuck's Avatar
Thanks MisterB I'm 6'3" I may have to rethink this!!!
Old 10-26-2013, 08:18 PM   #9
Mister-B
Yeah, and keep in mind that new foam on the seat back that's too thick can push you closer to the steering wheel, to where some guys have complained of belly fitment issues. I'm not trying to discourage you. Just saying to test fitment, because having your head up by the roof, with your belly rubbing on the wheel can't be too comfortable
Old 11-06-2013, 11:54 AM   #10
yote1234
yote1234's Avatar
yes sir! that would be me!! new foam put me much closer to the steering/dash than anyone would want to be..
i even had a 5'10 140 pound friend with no beer belly to climb in behind the wheel only to complain of "too close to everything" mostly complaining of no leg room.. it was as if the seat was slid all the way foward! still havent found a fix!
H E L P !
1971 K5 CST Blazer
1965 Chevelle Malibu 283 (sadly sold)
1968 Camaro 327
1968 Honda mini-trail z50a #377
1966 uh 1-D Huey
yote1234 is offline   Reply With Quote
Old 11-06-2013, 12:01 PM   #11
Lattimer
Lattimer's Avatar
H E L P !
Electric carving knife and a steady hand.....
Shawn
Old 11-06-2013, 03:27 PM   #12
yote1234
yote1234's Avatar
as last resort i might.
1971 K5 CST Blazer
1968 Camaro 327
1966 uh 1-D Huey
