Old 10-26-2013, 11:18 AM   #1
*71SWB*
Posi track and gears question
Is there a major difference in the 3.42 & 3.73 gears? Currently I believe I have the 3.08. Has anyone had both? I am trying to decide which to have put in
*71SWB* is offline   Reply With Quote
Old 10-26-2013, 11:57 AM   #2
zeldman
zeldman's Avatar
Re: Posi track and gears question
A little more info please, such as transmission type and motor type. Are you a red light to red light person or are you looking for cruise RPM. For a big block with a standard tranny I would go with 3.43 gears. A small block with an auto I would choose the 3.73. If you have an OD tranny then I would go with 3.73 or maybe 4.11. For me it depends on what I want to do with it.
2005 GMC K2500HD D/A
1993 GMC K1500
2011 Subaru Legacy.
2013 Subaru Outback
1970 C-10 2WD, SWB stepside, 292, TH350, PS, more rust than anything. God is my pilot.
zeldman is offline   Reply With Quote
Old 10-26-2013, 12:13 PM   #3
*71SWB*
The motor is SBC 350 and the tranny is TH350 (no over drive). I'm looking for cruising.
Would there be significant difference in RPM between the 3.42 & 3.73 ?
Old 10-26-2013, 01:41 PM   #4
Fitz
Go here:
http://www.grimmjeeper.com/gears.html
And before anyone whines "But it's a jeep calculator", yes it is a jeep calculator but it lets you do FWD's too! Use the pulldown menu to find your trans. Click no lockout torque converter, enter the number one in the boxes for high range, low range and stak 3rd range. Enter a rear end ratio, specify tire size and press calculate. It will display road speed vs RPM for three different values in each gear and other useful stuff.
Change the rearend gear ratio and do over.
Now you'll be able to compare any combination of trans, overdrive/no overdrive, tire size and rearend ratios for RPM ranges, crawl speeds and other cool stuff.
Have fun!!!
Fitz is offline   Reply With Quote
Old 10-26-2013, 03:20 PM   #5
68350
68350's Avatar
My setup is 295/65/15 tires, 3.42 Eaton posi, th400 and at 70 its roughly 3000 rpms. My 496 with a holley double pumper will pull 10-12 at 70 cruising down the highway.
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
Old 10-26-2013, 05:20 PM   #6
54belair
54belair's Avatar
If youre into cruising-----without overdrive---Id stay with the 3.08's
These trucks dont get good mileage no matter what you do--but the 3.08's will sure help.
Im currently building my 68----I pulled a 700r4 and Im installing a muncie M 21----Just my personal preference-----With 3.08's Ill cruise at 65-ish @2400 (ish) difference between 2400 rpm and 3000 rpm will be significant to your wallet.
Here again man, its all personal preference. I built my engine for low rpm and higher torque to help with off the line, after I get into 4th the 3.08's will work for me.
1997 shortie stepside
1968 short stepside
1966 mustang
1966 chevelle ss
Dont always go the cheapest route--You can save yourself into the poorhouse!
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=489030
54belair is offline   Reply With Quote
Old 10-26-2013, 05:44 PM   #7
hugger6933
I think one of the best all around gears seems to be the 3:42. I am building two 70's and one 68 and I feel that they all have the standard ratio rear [for the 70 it will be 3:73] I have not looked up what was standard in 68. Probably those gears will remain just because it is easier to leave them. One 70 will be a small block very mild, with a T-5 trans the other close to stock 454 T400. The 68 will have a slightly warmed 454/4L80E. So while I am all over the place on the power plants, unless the first or second get changed out for LS power [I need to clear out some drive train stuff] I have it laying everywhere around and in my shop, the ratios seem to be the only thing consistent in my builds at this point. Jim
hugger6933 is offline   Reply With Quote
Old 10-30-2013, 07:26 PM   #8
*71SWB*
Man I hate to ask one more questions about which gear to choose. I guess my issue is I really like the thought of the quickness from light to light with 3.73 however I really only cruise around town and like that aspect of the 3.42. I have th350 and 275/60/15 and 23-2700 converter. The calculation shows 3.73 will be 3075 rpm at 65 mph and 3.42 will be 2819 at 65 mph. Will the converter make any difference between the two? AND my last question - is there a significant difference with the 3.73 vs 3.42 considering light to light aspect ?? Thanks everyone for bearing with me and my questions..
Old 10-30-2013, 08:20 PM   #9
Fitz
Converters do slip so the rpm's will be higher than your estimates by 100-200. You are also about to discover what happens when you increase the stall speed of your converter. Unless you keep the rpm above the stall your trans is going to run hot. With the way you say you drive, loafing around town (with business and residential speed limits) and 3.42 rear gears you aren't ever getting above the stall speed of that converter unless you say in second gear all of the time. I would take that truck back to a stock stall speed converter or add a trans cooler or both!
Old 10-30-2013, 08:44 PM   #10
In The Ten Ring
What about a 250 I6, 3 on the tree, positive traction, and 3:73 gears?
Right now I have a 4:11 posi trac and the gas mileage is crap and top speed is pretty low.
If I go to 3:73 will it go faster and get better mpg? Can I keep the posi trac?
In The Ten Ring is offline   Reply With Quote
Old 10-30-2013, 09:04 PM   #11
*71SWB*
So if I'm understanding correctly the 3.73 is what the converter I have requires considering the tire size and th350
Old 10-31-2013, 07:43 AM   #12
Keith Seymore
Keith Seymore's Avatar
I'm right there with you guys on this one.
We historically always started with 3.42 and moved off that depending on what we wanted.
More pep off the line? Adding an overdrive? Start going up (numerically) from there.
BTW - the 3.73 in my truck is perfect. 4.3L V6, MY6 overdrive (.73:1) trans, 3.73 posi, P235/75R15 tires.
K
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 11-01-2013, 12:52 AM   #13
Fitz
If it were my truck (I enjoy the stoplight wars) I would go with a 3.73 rear. If you drive like my girlfriend (130 on the interstate but sedate around town) then 3.42! Either one is a good choice. Use the calculator and you'll see that there is not a lot of difference and if you THINK you made a mistake shift the tire size for a test run! You can make a 3.73 act like a 3.42 and vice versa (almost) by changing tires.
Old 11-01-2013, 06:18 AM   #14
bigmac73
bigmac73's Avatar
why so big on the stall converter? unless you are doing some serouis drag racing anything bigger that a 2500 RPM for the street is over kill
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 11-01-2013, 07:38 AM   #15
*71SWB*
I thought I was getting a small converter when I ordered it. I ordered it from jegs and the listing shows 23-2700. I thought that was what I needed, however I am the extreme non-mechanic.
Old 11-01-2013, 03:19 PM   #16
bigmac73
bigmac73's Avatar
back when i was a young man i had another 72 C-10, 307 3 on the tree, with 3.08 rear end, i put in a 350HP crate engine and a turbo 400 and a B/M Holeshot stall converter i think it was 2100RPMs with a Holley 650 DP and did some tweaking on my advance springs in my Dizzy and it ran great off the line, but since i had those 3.08's in the rear end i would give the 5.0 Gt's prettyboys a run for there money on the highway and it cruised great, this was back in the early 90's when every punk had to have a mustang
i would see if you can exchange the converter and get a 2100 stall
Mike
Old 11-06-2013, 03:15 AM   #17
oldspowered67C10
If it helps, I believe if you want to run 3.73s you need to change the carrier.
oldspowered67C10 is offline   Reply With Quote
