Matte/satin paint care
Hey guys ive got satin paint on my truck and it get really bad water spots after i wash it. done a little research and have heard sworn testimonials from everything from silicone spray to motor oil. whats really the best? thanks in advance
Re: Matte/satin paint care
![]() Join Date: Oct 2009
good question. I know it's not much of an answer, but I haven't found ANYthing that would work better than wash then wipe. Preservatives, etc seem to screw up satin finishes (I'm mostly talkin underhood stuff though, but same principle if it's your exterior). I'd be interested to hear of there's a better way also. Personally, I wouldn't use silicone or oil on a satin surface, just a temporary lustre that will shorten the finish's life.
called up my old man (he's a long time hot rodder) he told me to use armorall tire care stuff. went to wallyworld and picked some up works pretty well. kinda smudges if you wipe your finger on it hard. might just need to let it dry or use less. i took a pic. check it out
1970 c20 cst 350/400 14bolt rear |
![]() Join Date: Mar 2012
will that dry? or turn into a dust catcher?
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
dang, looks good!!
I would try a water softner in the rinse.
Man of Mini-Talents
I use detailer on mine.
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
Thats dry. I just apply it with a sponge (use alot) let it soak in. Then wipe it down with a mf cloth. It might get a little splotchy overnigh so just apply another layer and it should last a couple washes before you need to do another layer. Or you can just do one after each wash like me
Pledge. Works great and resists dust. does give it a little shine though. More like the result w the Armour All
![]() Join Date: Jul 2012
I simply dry mine off with a shammy. works every time.
![]() Join Date: Oct 2012
Supposedly this stuff is really good. SPI has been sending out a free bottle (they had to actually buy it) with all of their matte black base. Wizards matte paint detailer.
1969 Chevy C10 SWB Fleet - Build thread > http://67-72chevytrucks.com/vboard/s...d.php?t=593554 2008 GMC Sierra Denali - 6.2L AWD - my daily 2011 Ford Flex Limited - Ecoboost AWD - wife's daily 1987 Buick Regal Turbo T - 63K miles - Strip/Street car 1965 Ford Mustang Coupe - 289, c4, 53K miles |
