Old 10-26-2013, 05:20 PM   #1
bigarmzz
bigarmzz's Avatar
New Summit 110gph sbc Mechanical Fuel Pump
recently bought a new GM Fast Burn 385 Crate Motor and have a few things left over.
New in the box Summit sbc 110gph fuel pump. Only time it was even out of the box was to take these pictures. Sells new for $55, will do $40 shipped
copied and pasted from there web site:
Summit® mechanical fuel pumps are available in two versions; one has ¼ in. NPT inlets and outlets, provides 5.7 to 8 psi, and can free-flow 80 gph. That's twice what a normal pump delivers. The other has 3/8 in. NPT ports, delivers 6.5 to 8 psi, and can free-flow a hefty 110 gph. These pumps are plated with a bright finish for good looks and corrosion resistance, and the lower housings of both can be rotated through 360 degrees, to make fitting into tight places a snap.
http://www.summitracing.com/parts/su...20-1/overview/
bigarmzz is offline   Reply With Quote
Old 11-05-2013, 02:04 PM   #2
bigarmzz
bigarmzz's Avatar
Re: New Summit 110gph sbc Mechanical Fuel Pump
bump, I know someone needs this
