Issues with LS swap and motor mounts
Yesterday I installed ECE mounts and the 5.3, and I'm having issues with the oil pan hitting the rear section of the crossmember. I used the top outer two holes on each side, and drilled two holes in the crossmember.
I see a bunch of other builds that have ECE mounts being used with no issues. Does the mounting of these look right? It seems like the engine needs to be moved back a little. ![]()
68 SWB 5.3 turbo build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=578220 |
Re: Issues with LS swap and motor mounts
Can you flip the mounts?
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
A day late and $1 short...
Does the 5.3L still have the truck pan?
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
I COMPLETELY forgot to mention I had an fbody pan, sorry.
F-body pan won't work with ECE mounts. 2007 CTS-V will fit and is shorter than the truck pan.
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD Last edited by C10_ustacould; 10-27-2013 at 01:35 PM. |
Damn damn damn.
I was thinking about putting some kind of spacer in there, but I'd like to avoid that. Is there a known specific mount that'll work with the fbody pan and the 73-87 style towers? If I could just ditch the mounts themselves and keep the towers, I'd be set.
Looking at the Dirty Dingo mounts, the site says they won't work with a low mount compressor, which is an issue with those.
I may have to go the spacer route.
#8 | |
How much space do you need?
![]() Join Date: Apr 2005
I would sell the Fbody pan and get the CTsV pan. That way you will not have to hassle with moving the a/c.....
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
I would agree with^^^^
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Truck and auto performance nut
subscribed
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
meowMEOWmeowMEOW
If you do need to tweak the frame, its really not as big of a deal as it sounds. On my 66 there is the "factory bend" in the frame where it bumps out for clearance. I just mimicked that when I wanted extra clearance for the pump/lines on my powersteering/hydroboost setup.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#13 |
![]() Join Date: Feb 2004
You can probably get an inch or two by drilling new holes in the frame and crossmember and sliding the towers back thats what i had to do on my homemade mounts so the headers would clear the lower control arm.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
#14 |
^^Rob, that's exactly what I'm going to do. I looked at it earlier, and figured I need a little under an inch backwards to account for vibration, etc. There's plenty of room under the hump for the tranny, but I think I'd have to go high hump with anything larger than this 4l60. The other plus of this is more potential room for ac condenser, radiator and intercooler.
I'd trade the pan out for the CTSV one and call it a day, but I already drilled a hole for the turbo drain in this pan. The only downside I can see is that moving it might present an issue for the ac compressor. I'll have to take a look at it when I get the cab off. I'll post pictures when I'm done.
#15 |
Location: Sunny, Florida, some might call it South Alabama
I had this exact same problem. I did two things to fix
1. Heated the k member with a torch and beat the hell out of it 2. I installed spacers between the frame and the mount brackets.
Just sold my C10...sad day... Looking for a 1972 Blazer to hopefully fill the hole in my heart. |
#16 |
Okay, got it all tightened up and now it's great.
Moved the mounts back about an inch from the original holes I drilled, on both top and bottom of the motor mount. One bolt will definitely be close to the edge of the crossmember, but it'll hold well. The other good part about that if you use the ECE transmission crossmember, you won't have to drill any holes. It's a pretty clean install actually. Bear in mind, this is all with a 4l60 transmission. Not really sure about the size of the sun shell on the 4l80. Oil pan: ![]() Auto trans crossmember: ![]()
