Questions on front air ride
I have a 75 c10 has 2.5 drop spindles already up front and wanna do bags as we'll for the ride and lowering desired. I don't need to be able to adjust, just the air up valves would work. What kinda bags do I look for (what size? Psi?)? And do I get brackets to attach to the factory spring cups? Very inexperienced when it comes to these bags. I want a low look and even set on the ground sometimes at a show if necessary.
Can someone out there help me out! Haha |
Re: Questions on front air ride
You just need bags, brackets and a air supply. Instead of valves you can do manual gauges which would be cheaper. If you just want to do the front this should be all you need, Travis at pro performance may even do a package deal for you
https://www.azproperformance.com/1-4...ement-Kit.html https://www.azproperformance.com/1-4...ement-Kit.html https://www.azproperformance.com/Air...tor-D2500.html |
