Old 10-27-2013, 11:29 AM   #1
Phyregod
Fooking for a '72 fuel tank fuel line and vent line routing diagram?
I'm looking for a diagram that shows where all the lines from the fuel tank go in the truck. I have three that go below the floor, I assume fuel line and vents, but there are also two that go up into the roof? Where are those headed? Does anyone have a routing diagram that shows how these are routed in the truck?
I have the tank out and I'm replacing all the rubber hose pieces, and want to make sure all the other ends are connected where they should be. Thanks.
Phyregod is offline   Reply With Quote
Old 10-27-2013, 11:38 AM   #2
Scott>72-GMC
Scott>72-GMC's Avatar
Re: Fooking for a '72 fuel tank fuel line and vent line routing diagram?
The roof one u are talking about is a vent should go up passenger piller and loop back down
72 GMC super custom.
Scott>72-GMC is offline   Reply With Quote
Old 10-27-2013, 12:04 PM   #3
Phyregod
Fair enough. Seems like all three end at the frame rail near the fuel pump. One is fuel, the others are just open to the atmosphere. I assume they should be connected to an emissions can and a vacuum line? Need that routing info.
Old 10-27-2013, 01:18 PM   #4
heyjoe
I pretty sure fooking is not allowed on the forum.
heyjoe is offline   Reply With Quote
Old 10-27-2013, 01:30 PM   #5
Fitz
You could try fooking in the factory assembly manual!
Fitz is offline   Reply With Quote
Old 10-27-2013, 03:10 PM   #6
Scott>72-GMC
72 had a return line and vent going to a charcoal can the return you need to have the right fuel pump. I'm dealing with the same issue. These are just my findings so far
Old 09-08-2020, 10:13 AM   #7
Tripmiester
Tripmiester's Avatar
Here you go
Tripmiester is offline   Reply With Quote
Old 09-08-2020, 06:09 PM   #8
toolboxchev
X2, They will ban you for FOOKING!
toolboxchev is offline   Reply With Quote
Old 09-09-2020, 04:15 PM   #9
Ekliptix
Ekliptix's Avatar
I installed EFI with my stock 72' in cab tank, and I used the return line.
Under the truck
1972 Cheyenne Super SWB PS, PB, Tach, A/C, Tilt.
Drivetrain: Built 402BB, TCI Streetfighter 700R4, 2,500 stall, Eaton posi, 3.73. Suspension/Chassis: ECE 4.5/6.5 drop, CPP nitrogen shocks, CPP front and rear sway bar, CPP cross members. Exhaust: 3" exhaust with x-pipe, Spintech 3000 mufflers, Hooker ceramic coated headers. Best 1/4 mile time: TBD.
Ekliptix is offline   Reply With Quote
