Old 07-11-2003, 06:29 PM   #1
rhett
Question cracked frame
hello,all. my ? is. the frame on my 70 c-10 has a crack on the hump right over the rear axle. can i weld this and then use a c-notch kit to to help make the frame stronger. also there is a rust through problem on the same side right where the coil spring mounts to the frame, i also thought the c-notch kit would help there also. any input would be great. thanks.
rhett is offline   Reply With Quote
Old 07-11-2003, 07:08 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
i would make two plates one for each side of the rotted area or cracked area and have em welded in good
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 07-11-2003, 09:55 PM   #3
82 'ject
Alleged Member
Just be careful with the welding. Not to much heat and weld only the sides along with the bolt supports. Welding along the top and the bottom of the frame isn't good.
82 'ject is offline   Reply With Quote
