Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1967-1972 Chevrolet & GMC Pickups Parts Board > Blazer and Suburban Stuff
Old 10-27-2013, 08:18 PM   #1
SONOSADSACK
SONOSADSACK's Avatar
WTB Seat Parts
Seat Pawl ?
OK, I’m not sure what it’s called but… I am looking for the three pieces shown in the picture AND the rod that connects them to the other set on the other side of the bucket seat track.
SONOSADSACK is offline   Reply With Quote
Old 10-30-2013, 07:17 PM   #2
SONOSADSACK
Re: WTB Seat Parts
again
Old 10-30-2013, 08:31 PM   #3
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Re: WTB Seat Parts
A bench should have everything but the rod if I remember correct. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 10-30-2013, 09:20 PM   #4
SONOSADSACK
Re: WTB Seat Parts
good to know - anybody?
Old 12-08-2013, 10:36 PM   #5
SONOSADSACK
Re: WTB Seat Parts
TTT - still looking for all three
Old 12-08-2013, 10:45 PM   #6
freakshow108
freakshow108's Avatar
Re: WTB Seat Parts
Try the board member Livrat, he has a lot of this stuff.
freakshow108 is offline   Reply With Quote
Old 12-12-2013, 08:06 PM   #7
atvpro
atvpro's Avatar
Re: WTB Seat Parts
Originally Posted by SONOSADSACK View Post
Seat Pawl ?
I have this stuff coming out my ears. just give me a call 509-990-3608
atvpro is offline   Reply With Quote
Old 12-19-2013, 11:18 AM   #8
themb2g
Re: WTB Seat Parts
atvpro, do you happen to have the seat bracket for the passenger side where it locks in?
Check out my build: 1972 LQ4 Swap
http://67-72chevytrucks.com/vboard/s...=1#post5427693
themb2g is offline   Reply With Quote
Old 12-19-2013, 11:26 AM   #9
atvpro
atvpro's Avatar
Re: WTB Seat Parts
no but I would have no problem getting my hands on them fairly quickly
Old 01-03-2014, 08:15 PM   #10
SONOSADSACK
Re: WTB Seat Parts
ttt
Old 01-04-2014, 05:15 AM   #11
Gary 70 Jimmy
Gary 70 Jimmy's Avatar
Re: WTB Seat Parts
I need the same parts if you have some more plus I need the rod in between the tracks and the heavy spring.
1972 GMC Jimmy 1/2 4X4 4wheel camper
1970 GMC Jimmy 1/2 4X4 350
1969 Chevy Blazer 1/2 4X4 307
1967 chevy LWB 3/4 396
Gary 70 Jimmy is offline   Reply With Quote
Old 01-05-2014, 08:01 PM   #12
SONOSADSACK
Re: WTB Seat Parts
ttt
Old 01-08-2014, 07:44 PM   #13
SONOSADSACK
Re: WTB Seat Parts
Old 01-09-2014, 08:37 PM   #14
LockDoc
The Older Generation
LockDoc's Avatar
Re: WTB Seat Parts
The local salvage yard just pulled a seat out of a C-50. I will go over in the morning and see if it has the parts you need. I know it is in pretty bad shape but who knows.
LockDoc
Leon
Old 01-10-2014, 07:25 PM   #15
SONOSADSACK
Re: WTB Seat Parts
Any luck?
Old 01-10-2014, 10:50 PM   #16
LockDoc
LockDoc's Avatar
Re: WTB Seat Parts
Any luck?
Here is a picture of the parts that were on the seat over at the salvage yard. The longer flat piece (I’ll call it a lock plate because it locks the track in each position) you have is for the passengers side. The lower lock plate in my picture is for the drivers side, because it has the notch for the adjuster handle in it. The linkage tab was welded to the drivers side lock plate so I had to grind the welds off with my cut off wheel. The tab is still useable but I cut the spring when cutting the welds. I have included a picture with with the measurements of the spring. You should be able to pick one up at any good hardware store or home center. You may have to shorten it.
I will be gone most of the day Saturday. I have to help a friend of mine put the glass in his '65 Chevelle.
LockDoc
Leon
Old 01-11-2014, 05:40 PM   #17
SONOSADSACK
Re: WTB Seat Parts
PM sent
