Old 10-27-2013, 08:26 PM   #1
matt_field
matt_field's Avatar
Looking for a shortbox 4x4 frame.. Year differences?
I've been looking hard for a frame for my 68 4x4 swb. Mine is rusty, beyond repair. I know 67 are kinda by them selves with the steering. Other that open knuckle front diff would a 1969 and later frame be the same? (71-72) with disk brakes.
Is there a part of the country that got more of these shortbox 4x4? I can't find anything in the Minnesota area
Thanks!!
Matt
1971 k5 blazer 80k mike survivor
1972 3/4 ton 4wd Cummins 12v
1967 swb 2wd 427bbc
1968 4wd shortbox
1971 Cheyenne swb k10 unrestored
1971 Cheyenne super 40k 402bb survivor
1967 Chevy k10 (first truck)
1968 L78 camaro survivor 18k miles
1969 z28 survivor 60k miles
1969 z28 survivor 39k miles
1969 z28 rs survivor 80k miles
matt_field is offline   Reply With Quote
Old 10-28-2013, 02:48 AM   #2
68_Shortbox
68_Shortbox's Avatar
Re: Looking for a shortbox 4x4 frame.. Year differences?
I don't know of any other differences between '67-'72 other than '67 and '68 leaf springs are tapered. The previous owner put axles from a '73 suburban in my 68' swb but it appears they had to modify the mounts on at least the rear axle. I haven't dealt with the front axle yet to see if it had to be modified to fit. Its not much to go on but I hope it helps you out. Maybe someone else that has dealt more with '67-'72 4x4s can chime in.
Build thread for my SWB 4x4 http://67-72chevytrucks.com/vboard/s...d.php?t=447938
1968 Chevy K/10 short box fleetside (my project)
1969 Chevy Z/28 Camaro (my dad's project)
1968 Chevy C/20 long box fleetside (parts truck)
68_Shortbox is offline   Reply With Quote
Old 10-28-2013, 08:27 PM   #3
fp1967
fp1967's Avatar
I'll add a little more info based on what I've seen. The 67's and 68's that I've seen had the flat frame behind the steering box with manual steering. All the 69-72's that I've seen, had the raised areas behind the steering box, this was on both manual and power steering trucks. I'm pretty sure the front leafs are the same from 67-72. The 67 and 68's used tapered leafs on the rear, 69-72's had non-tapered 2-1/2" wide rear leafs. The front axles bolt up the same from 67-87. The rear axles bolt up the same from 67-72. As far as finding a good frame, I can't help you on that. I'm two states away in the U.P. of Mich and I couldn't find a good swb 4x4 frame in 1986. I used the back of a swb frame and the front of Suburban frame and spliced them in the area of the transfer case crossmember. Thats whats under the truck in my avatar.
fp1967 is offline   Reply With Quote
Old 10-28-2013, 10:00 PM   #4
68_Shortbox
My 68's front leaf springs are tapered just like the rear.
Old 10-29-2013, 04:01 PM   #5
fp1967
fp1967's Avatar
As far as I know, all the 67-72 front leaf springs are tapered and interchangable.
Old 10-29-2013, 05:49 PM   #6
matt_field
matt_field's Avatar
thanks for the info guys! i put a wanted ad on the site, hopefully someone has a clean one for me. I hate to put rust free cab and box on a pitted thin frame.
Matt
1967 swb 2wd 427bbc
1968 4wd shortbox
