Loose Steering Column?
So I have an 89 Jimmy that had some loose steering. I wanted to fix it so I replaced all the tie rod ends and power steering gear. All the moving stuff in the front is new, so my question is: are there parts in the steering column that can wear out and cause slop? Or is it just normal with wide tires and a 4" lift to feel like you're sawing logs to keep it going straight. 32x11.50's btw.
Re: Loose Steering Column?
Loose steering linkage and big tires equals a truck (or jimmy) you can hold in the road. Most likely its not in the column, but could be steering box loose also. But before I spent $$$ on a rebuilt box, I would fix everything else and check the frame where the box mounts. With the bigger tires you should invest in a steering box brace kit like yesterday!
#3 | |
you can get sidewall flex running 15 inch rims and 33s. but every 4x4 solid axle I have had had issues with the front spring mounts flexing.
1985 ![]() |
Might be a dumb question, but did you replace the Pitman and Idler arm?
Scott 87 Chevy 2WD SWB, 88 4x4 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=610652 |
No one has mentioned this little guy yet, but how's the rag joint?
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 |
