10-27-2013, 11:20 PM | #1 |
i need front bump stops where can i get em
Ok so i ordered some from energy suspension caus the pic looked right but they are not. I need som lower control arm stops for my 68 that will replace the oe. Preferably poly and not rubber. But the ones i got are push through but the groves are not wide enough to allow them to snap in. I think they are for a car. I need some that are at least as tall as oe caus the fender tire clearance is tight. Le me know what yall are running
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
10-28-2013, 11:55 PM | #2 |
Re: i need front bump stops where can i get em
check auto part stores for some universal type bumpstops. they sell them in various sizes and only require a small hole for the stud and bolt. Thats what I did on mine. Got the tallest ones, cut them to size, drilled a hole in my lca and bolted them in. Easy.
10-29-2013, 09:18 AM | #3 |
I saw some rubber bumpers on Brothers Trucks this morning. I'd give them a call to confirm they'll fit your ride.
8/24/13 First Classic Truck '67 Short Fleetside, Candy Apple Red! 350ci, Holly 750 double pumper (too much, will change soon), Headers with FlowMaster exhaust, 700R4 tranny. |
10-29-2013, 09:49 AM | #4 |
I just ordered some from rockauto.com
10-29-2013, 07:18 PM | #5 |
Grooves are long enough, but too narrow to easily slide in? If so you probably have the right ones. Are you using the vehicle weight to install them? Lube the caca out of them and put them in the groove, wedge a board in there with it jacked up, then let the jack down. It should pop in relatively easy.
10-29-2013, 11:32 PM | #6 | |
10-30-2013, 09:55 PM | #7 |
Did you check here? http://energysuspension.com/assets/f...on-catalog.pdf
