Radio Delete Clips
Does anyone make these things aftermarket/reproduction?
Thanks! Last edited by ItWillBeSlow; 10-28-2013 at 06:39 AM. |
Re: WTB Radio Delete Clips
what is a radio delete clip?
Clips that hold on the radio delete plate for non-radio trucks.
Re: Radio Delete Clips
ok havent seen those before but i would fill the hole with a radio but thats me
#5 | |
![]() ![]() Actually, mine does currently have a radio in it, but its non working, ugly, and I have plenty of other things to do to the truck before it gets fixed up. I just want to put the plate on now to get some wiring and junk out from behind the dash. |
understand! but any money i had is in my 70c10. its a daily driver and the first thing i had to have some jams. good luck with your project
The Older Generation
To the best of my knowledge they are not reproduced. LockDoc
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help. Heres another dumb question, what do these clips attach to? It looks like there would have to be a bar of some sort right in the radio hole. I do not beleive mine has that (radio in currently) Last edited by leddzepp; 10-28-2013 at 01:06 PM. |
The clips rotate with the radius that slides up under the metal edge that has been rolled over on the cover. On the clip is 2 spring clips that are formed at 90 degrees to the slide pieces and those clips are supposed to pop into the 2 round holes in the dash.
If you find a source for the clips, let me know because I've only got 1 clip also. |
#10 | |
If your radio hole has been cut out for a later style radio the delete plate will not work. The original radios have a rectangular hole for the faceplate and a round hole for the knobs to stick through on each side. LockDoc
That is correct. The original (radio delete) dash had a small rectangular hole with 2 round holes on each side. The radio delete plate covered the entire area and the clips popped into the 2 round holes.
Some dashes have been altered over the years by hacking and wacking to install different radios. |
#13 |
#16876
I'd bet a couple of modified Butterfly molding clips and a homemade cross brace would fix that up pretty easily.
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" ![]() Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. Last edited by Sillyoldman; 10-28-2013 at 07:51 PM. |
#14 |
Active Member
![]() Join Date: Jul 2007
Here's a pic I took of my cup holder when I had the radio off. It shows the stock radio openings.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
#15 |
Thanks a lot for the responses guys, lots of help.
I think I may still be good. 68gmsee, that pic is exactly what I needed to see to get my dumb slow brain to understand how they clipped in. Thanks! |
#16 |
How about using a thin magnet to hold it in place???
#17 |
#18 |
High strength Velcro strips @ your hardware store would work without breaking the bank.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
#19 |
i've used magnets before i had the clips.
radio shack has a good selection of magnets
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
