Old 10-28-2013, 02:31 PM   #1
VDOG
Grand PooBaa Member
VDOG's Avatar
Gas Tank Capacity
I keep looking on her yet to find what is the gallon capacity of our stock in cab tanks? I get to about 12 gallons and start to overflow.
VDOG is offline   Reply With Quote
Old 10-28-2013, 03:12 PM   #2
Keith Seymore
Keith Seymore's Avatar
Re: Gas Tank Capacity
Approximately 21 gallons.
http://www.gmheritagecenter.com/docs...olet-Truck.pdf
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 10-28-2013, 03:34 PM   #3
Longhorn 70
Longhorn 70's Avatar
There must be some reserve. The most I have ever put in is about 18.5 gallons........
The 21 number sounds real to me.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 10-28-2013, 04:29 PM   #4
Lee H
Lee H's Avatar
From my owners manual, C & K10s 20.2. C20 & 30s. 21.0.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 10-28-2013, 04:34 PM   #5
Lee H
Lee H's Avatar
Originally Posted by Keith Seymore View Post
Just opened this doc, WOW. That's a load of info, thanks for posting. Lee
Old 10-29-2013, 06:40 AM   #6
Keith Seymore
Usually there are two or three gallons "unusable", due to the pickup tube location and lack of a sump.
You are welcome
K
1979-1986
1986 - 2019
Old 10-29-2013, 06:48 AM   #7
Fldawg
Fldawg's Avatar
well someone must have changed mine because the most i've ever put in it was 15.5 gallons and that was when i was on fumes
Fldawg is offline   Reply With Quote
Old 10-29-2013, 06:51 AM   #8
Fldawg
Fldawg's Avatar
just looked at an older post some said gas tank options for these trucks were 16 and 20 gallons
Old 10-29-2013, 09:04 AM   #9
I have never seen where an optional fuel tank was offered. I have only owned trucks with 21 gallon tanks. Too many times I've put over 20 gallons in,then considered myself lucky that I made it.
Old 10-29-2013, 09:24 AM   #10
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Disconect your gas gauge. You will find Exactly how much your tank holds.
ask me how I know. lol
Tom Vogel is offline   Reply With Quote
Old 10-29-2013, 10:24 AM   #11
heyjoe
At the risk of redundancy.
1967 Chassis Service Manual states:
All cab models (except Tilt Cabs) have a 21 gallon capacity (approx.) fuel tank mounted behind the seat within the cab.
Then it goes on to talk about frame mounted tanks, but doesn't mention any different capacities so I assume these are also 21 gal. The Service Manual goes on to say the Van Fuel Tank is 20 gal. (approx).
I learn something new daily. I always figured the tank capacity was about 18 gallons, solely because I've never filled it with more that 17.6 gallons in the 30 years I have owned it and believed then I was running on fumes! Good to know!
Knowing this info, I have no plans to test this the hard way!
heyjoe is offline   Reply With Quote
Old 10-29-2013, 10:25 AM   #12
68gmsee
Active Member
68gmsee's Avatar
Originally Posted by Tom Vogel View Post
Disconect your gas gauge. You will find Exactly how much your tank holds. ask me how I know. lol
Even if you run out, there's still a slight amount left in the tank since the sending unit suction tube does not touch the bottom of the tank. Not sure how much, though. Maybe a gallon?
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 10-29-2013, 11:06 AM   #13
heyjoe
What worries me when running at or near empty is being on an overpass in stop and go traffic. Many overpasses in my area are built with a list to one side so what happens is the fuel runs away from the pickup towards a rear corner.
Old 10-29-2013, 12:07 PM   #14
Keith Seymore
Probably.
K
1979-1986
1986 - 2019
Old 10-30-2013, 09:27 AM   #15
I know the pick-up isn't on the bottom of the tank,but it's damn near cuz I have pumped over 20 gallons on many occasions
Old 10-30-2013, 10:36 AM   #16
LockDoc
The Older Generation
LockDoc's Avatar
You also have to take into consideration that the gauge and or sending unit could be off by a couple of gallons, easy. When the gauge reads empty the tank may not be as empty as you think. With my Red '70 I know for a fact I can drive 30 miles after the gauge reads double "E". Then you have to walk...
LockDoc
Leon
Old 11-03-2013, 11:40 AM   #17
VDOG
Grand PooBaa Member
VDOG's Avatar
Im going to have to agree with Fldawg, I have actually top off from being empty to about 12 to 13 gallons. Thus my confusion. My gas gauge does not work, so I use tried and true stick in the gas tank method.
Old 11-03-2013, 11:44 AM   #18
magicoolbus
magicoolbus's Avatar
Sound like you may have had a sender replaced at some time. I suspect that the pick up tube is not going deep enough in the tank.
JB from AZ
1969 Chevy Sub K10
1957 Chevy 3200
1962 VW Beetle
1957 Willys CJ5
magicoolbus is offline   Reply With Quote
Old 11-03-2013, 12:11 PM   #19
leddzepp
Moderator
leddzepp's Avatar
I have never been able to get more than about 13 gallons in an empty tank either, regardless of what anybody or any book says the capacity is.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 11-03-2013, 01:02 PM   #20
dlh760
dlh760's Avatar
The most I've ever been able to put in mine was about 16.5 gallons. That's with running out of gas pulling into the gas station ,taking off the cap, shining a flashlight down inside to see a literally dry tank then filling up until it spilled out slightly. So I would have to say its a 16 gallon tank and from what I can tell it is the original tank in my truck. Dan.
68 Chevy c10 longbed 307 with 305 H.O. heads,edelbrock performer intake,edelbrock performer plus cam,hei,Holley 650 double pumper and th400. Daily driver. It hauls butt,it hauls my butt where I need to go
dlh760 is offline   Reply With Quote
Old 11-05-2013, 05:33 PM   #21
VDOG
Grand PooBaa Member
VDOG's Avatar
Thanks Leddzepp, that has always been my problem. Good to know im not that crazy. LOL
Old 11-05-2013, 06:16 PM   #22
hopped up
hopped up's Avatar
mine sure has never taken 20 gallons! more like 13-15 the most. and thats on E
hopped up is offline   Reply With Quote
Old 11-05-2013, 08:00 PM   #23
VDOG
Grand PooBaa Member
VDOG's Avatar
See anything other than a San Diego trip we would need to take extra gas for those long drives with no gas stations.
Old 11-05-2013, 11:08 PM   #24
ItsRandy
ItsRandy's Avatar
No Vince...you're crazy but that is a subject for another time. LOL
Take a one gallon gas can, fill it up, put it in the bed of your truck and go for a drive. When you run out of gas put the one gallon in the tank, don't forget to save a little in the can so you can prime the carb. Drive to the closest gas station and fill 'er up. Not only will you find out how much your tank holds (remember to count the gallon from the can) but you will find out how accurate your fuel gauge is and what "empty" really means.
ItsRandy is offline   Reply With Quote
Old 11-05-2013, 11:11 PM   #25
ItsRandy
ItsRandy's Avatar
Sorry for the double post.
