10-28-2013, 08:09 PM | #1 |
How to remove hourglass style bolts?
Anyone found a good way to remove the bolts with the hourglass looking hole on top?
My flat heads are either too small or too big. |
10-28-2013, 08:14 PM | #2 |
Re: How to remove hourglass style bolts?
These screws are known as clutch head screws, they make a screwdriver or bits to fit these, common on the AD trucks.
1950 Chevy 3100 |
10-28-2013, 08:21 PM | #3 |
You can pick these up at most automotive stores. But, you probably won't find them at the local Wal-Mart. I just got a set of bits and a driver from Auto Zone.
daveboy |
10-28-2013, 08:57 PM | #4 |
Harbor freight has a 40 piece set that has 3 sizes of these bits, Menards has a 16 piece set that has 2 sizes of clutch head screws. Both are fairly cheap.
10-28-2013, 11:04 PM | #5 |
I don't know whose it is but whoever has the GIANT avatar of their torn up GMC interior can you PLEASE change it to a normal size like everyone else has?
I can't imagine I'm the only one who is seeing this. I check in on the site on my phone and this giant photo screws up trying to see anyone's response.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
10-29-2013, 09:33 AM | #6 |
Cool. Thanks for the info. Gotta make a Harbor Freight run, I'll grab a set.
10-29-2013, 12:35 PM | #7 |
for interior screws i grind a flathead screw driver to fit in the slot, then i discard the screws
for the rear fender to bed bolts i bought a single clutch head socket from snap-on back in the early 70s
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
10-29-2013, 01:11 PM | #8 |
Classic Parts sells a set of four clutch head screwdrivers. Absolutely necessary if you are serious about restoring or maintaining the AD or TF trucks.
http://www.classicparts.com/1941-66-...ctinfo/98-001/ |
10-29-2013, 01:15 PM | #9 |
^ yep !!!!!
10-29-2013, 01:38 PM | #10 |
For the ones in rear fenders,I welded a nut to the top and used my 3/8 impact to take them apart.I used a modified flat blade screwdriver on interior screws.I replaced all with new hardware on reassembly
1957 3100 1950 5 window |
10-29-2013, 09:03 PM | #11 |
And I have clutch head sockets from Snap-On.
Gale Gorman '54 3100 '67 C20 stepside |
10-30-2013, 07:14 AM | #12 |
Hope they worked better for you than they did on mine. All they did on mine no matter how hard you pressed was rotate right of the hour glass slot or round the slot out, still looking for a way to get mine out.
10-30-2013, 08:40 AM | #13 | |
It would be easier to access the bolt head but it will tear out the indentation before the nut comes loose. It helps to use Kroil or something on the threads a few hours before attacking it.
10-30-2013, 11:02 PM | #14 | |
10-31-2013, 06:24 AM | #15 |
I've got some like-new visegrips, and if you clip them on nose-first, they fit 'em perfectly! (Well, now you guys know how screwed up I am...)
Bob "It won't take long and it won't cost much." '55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed) Bob's Retirement Build - My 55 TF Bob's 700R4 Build (how-to) |
10-31-2013, 11:25 AM | #16 |
Great info. That's why I love this place.
I didn't want to buy the whole kit that HF had. I'm going to try that robertson bit, if all else fails... Snap-on. I like the idea of the bit design, but I'm swapping mine out to more standard heads. |
10-31-2013, 01:01 PM | #17 |
I have Snap-On tools so it wasn't a stretch to buy the correct tools. My '67 step side uses Phillips head bolts. I don't know when the clutch head was phased out but there are four different sizes used around the '54.
11-01-2013, 03:12 PM | #18 |
If you weld a bolt to the head of the clutch head it does two things- heats and loosens the rust, then use a regular socket to remove, less chanch of snapping off( use higer than norm heat setting on welder)
