Center vent with Vintage air
When using the factory center vent with Vintage air did you make a plenum box or run the hoses to the vent balls? I'm leaning to make the plenum box.
Re: Center vent with Vintage air
I used the box.
You have to go way back in time to get the answer from the Oracle of Chevy Questions.
Here is the link. http://talk.classicparts.com/archive...hp?t-2443.html |
I used the orginal box ....I trimed off the unnessary parts of it and then attached two connectors for the air hoses
Thanks guys
I don't have an original air box...... Time to fab something up! |
Its not going to be easy to fab one ....the dash is not a flat surface....the orginal vent attached to the orginal box....good luck....post a pic when completed
