Old 10-28-2013, 09:09 PM   #1
Houston Ben
Houston Ben's Avatar
5.3 intake flap question
Hi all,
Is the throttle body flap supposed to move when the ignition is in the ON position but not started? My flap seems like it wants to move when the gas peddle is pressed but barley budges, is this normal? There is also a high wine coming from somewhere on the engine when the ignition is in the on position??
any thoughts??
Houston Ben is offline   Reply With Quote
Old 10-28-2013, 11:06 PM   #2
downbytheriver
downbytheriver's Avatar
Re: 5.3 intake flap question
It's probably some kind of startup check to verify the position of the tb.
68 SWB 5.3 turbo build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=578220
downbytheriver is offline   Reply With Quote
Old 10-29-2013, 12:25 AM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Originally Posted by Houston Ben View Post
Hi all,
any thoughts??
Assuming that you have a dbw truck, when the key goes to the on position, the throttle goes open then back to its resting 98% closed position. This is to check the dbw components. If you are pressing the gas pedal and the tb does not change postion (i.e., your input does nothing to the TB) then you probably have a mismatched/miswired/misprogrammed setup. You need to verify that the dbw components are all from the same year, wired correctly, and that the tune was setup to run a DBW truck.
What kind of whine? Key on but engine off?
Fuel pump will make noise, dbw components make an electric motor noise for a couple seconds.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 10-29-2013, 02:24 PM   #4
Hart_Rod
Hart_Rod's Avatar
Hi all,
any thoughts??
Not sure about the pedal, sounds like a mismatch of components. The whine is coming from the transmission TCM and that is normal for a 6LXX.
Hart_Rod is offline   Reply With Quote
Old 10-29-2013, 03:39 PM   #5
Houston Ben
Thanks for the replies guys!
Yes, the truck is DBW, so the flap should move when the ignition is on but engine not running? This was supposed to be from the same vehicle, how do I check to see if the pedal is from the truck??
Hart Rod, thanks for the info on the whine, thought I was going crazy!
PCM is back at the tuners shop, we will see what happens when he sends it back.
Old 10-29-2013, 04:52 PM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
The flap would move on its own briefly, yes. If its moving all over the place after that little check, then there is an issue.
Have you cranked the truck over? A dbw mismatch might not be 100% evident until you try to apply pedal input with the truck running. Sometimes it will even allow a few sweeps on the pedal, before dropping itself into a dbw mismatch code (there are a few different ones). I initially had a later model pedal on my truck, and it allowed me to rev once or twice before going limp.
Old 10-29-2013, 05:28 PM   #7
Houston Ben
Yes, it does briefly so I guess it is ok. As far as the pedal, how would I know if it is from the engine or is a mismatch??
Also, does anyone know if the 2011 5.3 came with EGR??
Thanks again guys!
Old 11-03-2013, 09:38 PM   #8
Houston Ben
Here is a pic of my pedal
and the wires going into the pedal
This is supposed to be the pedal it came with.
Old 11-04-2013, 01:36 AM   #9
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
You could have at least put the pictures right side up.....
That is the part number for the 07+ trucks, so at first glance it would appear right to me.
Old 11-05-2013, 01:37 AM   #10
jorgensensc
jorgensensc's Avatar
High pitch whine is tranny. 6l80e right? If so it's the TCM.
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
