C10 C-notch finished process
Here is my process for my 75 c10 c notch process also has a axle flip kit and 2" lowering shackles
Re: C10 C-notch process
Photo two, bracket cut out
Test fitting and drilling bolt holes
Install bolts and washers and tighten
C notch finished and 2" drop shackles installed
Inside view of finished bolt on mcgauheys c-notch
Re: C10 C-notch finished process
looks good on the notch... but what's your pinion angle set at? looks a bit steep...
-'73 c/10 - Low with Go - will be complete... probably never. -'90 2wd Blazer - well... soon enough anyways. -'84 SWB - the daily gas guzzler. |
I noticed you only have to leafs on your springs. What is the ride quality like? And do you have plenty of travel with the notch?
are hangers on backwards ?
I'm just glad to be here!
I'd flip the shakles around...
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
