Old 10-29-2013, 02:13 AM   #1
jbristo67
resident oilfield trash
jbristo67's Avatar
Stats on this blazer
This is the stance I'm going for. I'm new to the lifting side of things I've always lowered everything I've had. How much lift and what size tires do y'all think this is? I'm also considering painting similar to this as well. Silver and blue instead of white and blue.
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 10-29-2013, 01:31 PM   #2
Ski-me
Ski-me's Avatar
Re: Stats on this blazer
Looks really high....maybe 8" or 10" lift?!
Tires are probably 38" or 40"
A lot of modifications are going to happen to make it drivable at that height.
Driveline issues
Steering Issues
etc.
- Jeff
89' K5 Blazer, 2.5" lift, 35" tires
04' GMC Yukon XL, 3/4 ton, 8.1L
Ski-me is offline   Reply With Quote
Old 10-29-2013, 02:21 PM   #3
68Timber
I know the pieces fit
68Timber's Avatar
Driveline issues
Steering Issues
etc.
x2
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 10-30-2013, 07:55 PM   #4
zaccaglin
zaccaglin's Avatar
Driveline issues
Steering Issues
etc.
X3.
Here's my burb in silver and blue to give you an idea.
Zaccaglin
1998 Chevrolet C1500 Ext. Cab 350
Former Rig:
1985 Chevrolet K20 Suburban 6.2L Detroit/TH400/NP208
zaccaglin is offline   Reply With Quote
Old 10-30-2013, 08:26 PM   #5
Unca
in looking id vote those are 36 inch tires or there about. so 6 to 8 inches of lift id say. ( you have to clear or cut the front fenders if you want to be able to turn) but now your looking at longer drive shafts, longer brake lines. driveline angles ( should be corrected in the lift kit). make sure the kit makes your draglink flat or bump steer becomes ugly. front end alignment, caster needs to be correct or death wobble ensues. ( think the ****ty shopping cart wheel wobbling as u push the cart... only this is your steer axle) the trans wont like the bigger tires, gear changes in both differentials. ( it might be drivable, but the ratios wont be fun.) the speedo will have to be corrected. ok i'm done being Mr. sunshine... but i've lifted a few rigs and know most of the normal headaches that come along with it. some trucks are easier then others. suspension lifts are good, there are some brands that are better then others. use also dictates what brands as some flex for trail use more then others... boulevard cruisers don't need flex, but then the log truck ride is not fun. multiple shocks are swell if your jumping, if not they are just expensive and ride for ****. steering stabilizers help, but the big rubber is still going to wobble n wander down the road... I can go on but ive rambled enough.
Unca is offline   Reply With Quote
Old 10-31-2013, 10:01 AM   #6
Ski-me
Ski-me's Avatar
4" suspension, 1" zero rates and 1" body lift on 38" tires....
- Jeff
