Old 10-29-2013, 02:34 PM   #1
Straight six
Straight six's Avatar
Gas in oil
Well I checked my oil this morning and I strong gas smell. I put a a new mechanical fuel pump in July. I have a new edelbrock on my 250 I had it sent back due to flooding high idle and band choke linkage so I put it on two weeks ago it's been running great. No I'm really worried about the smell in my oil. I know I'm do for oil change
Straight six is offline   Reply With Quote
Old 10-29-2013, 03:45 PM   #2
Dead Parrot
Re: Gas in oil
You have already mentioned the two most likely sources, bad engine mounted fuel pump and a leaky carb. It is possible the gas is left over from the earlier carb or pump issues. Do you have a working PVC system? One of its functions is to pull unburnt gas out of the crankcase and back into the intake.
I would change the oil so you know any gas from previous issues is gone and just frequently check the oil for new gas.
Dead Parrot is offline   Reply With Quote
Old 10-29-2013, 04:00 PM   #3
meatwagon83
meatwagon83's Avatar
Re: Gas in oil
I put $20 on a ruptured fuel pump diaphragm
"DON'T TOUCH THE TRIM!!"-Early Kyler
meatwagon83 is offline   Reply With Quote
Old 10-29-2013, 05:34 PM   #4
geezer#99
geezer#99's Avatar
Re: Gas in oil
I put 20 on too much fuel pressure!
Old 10-29-2013, 06:16 PM   #5
Straight six
Re: Gas in oil
I'm getting a steady 6psi
Old 10-29-2013, 06:23 PM   #6
geezer#99
geezer#99's Avatar
Re: Gas in oil
Edelbrock says 6 to 6.5 max pressure. Real world says 5 psi.
Look in the carb while it's up to operating temperature. Shouldn't see any raw fuel, not even a drip.
If you do see fuel you'll need a regulator.
In fact it's safer to put a reg on anyway. Only 30 bucks compared to a motor rebuild from washed cylinders.
Old 10-30-2013, 11:47 AM   #7
D13
D13's Avatar
Re: Gas in oil
Change you oil and filter.
Keep an eye on the level and smell.
My 250 likes no more than 3 1/2 psi, any more and it wants to flood and run rich. How big is your carb? Remeber these things like a small carb for street driving, anything over 500 is bad and hard to tune. 350 is best.
Do you have heat on the bottom of the intake? if not you will get fuel puddling and can wash down the cylinders.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 10-30-2013, 07:38 PM   #8
Straight six
Re: Gas in oil
Did oil change so far no gas smell
1978 GMC C15 4.1 250
Twitter: StraightSix78
Instagram: StraightSix78
