Beginning Restoration (Engine, Trans, Additional...)
Hey Team:
I am beginning my prep work for my restoration and although mechanically astute, I have never implemented these skills in an engine and transmission. I plan on this truck becoming my daily driver, mostly highway or driving 8 miles down a two lane road. I do the occasional tow with my trailer (3-5K lbs) and do not have a lead foot, but care about the ability to merge onto a freeway quick if needs be. I have been reading a ton of posts and articles on which engine/trans combo to go with and have narrowed it to a GMPP 350/290HP with the 700R4. Not sure of gear ratio yet... Not sure if it matters regarding what trans to put in, but I am a larger guy, over 6'4'' and 300 lbs, so I am also considering putting in some HD coils to raise the truck just a little bit and maybe taller then normal tires. While I have the engine and trans pulled out, what are some other things I should consider doing? I have read about fuel injection, I do care about MPG, should this be a must install? I have done a ton of reading prior to posting this, so please be understanding to my newness... |
#2 | ||
"I ain't nobody, dork."
Re: Beginning Restoration (Engine, Trans, Additional...)
Brakes... go through the entire brake system. Havin' all the go, will be no fun without the whoa...
![]() Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
#3 | |
Haha great way to phrase it. I have been doing quite a bit of reading on the disc brake conversion. Still no where near the comfort I should be at to accomplish this, at least I think, but also feel it should be done in sync with the engine/trans. Correct? |
Seeing as I want to try and do the swap myself, the crate engines seem like a great option.
BUT I also continually read on newer vortec engines being tossed in with ecu that work with our older trucks. This is a foreign concept to me, but hear of the great mpg increase with such a swap and that is attractive to me. Should I also consider something like this?
-JASON My grandpa, Gramps, won a 1970 C20 in 1969 for $1. I'm on a mission to restore it before he passes. My 1970 C20 Build Thread |
I'm in the final stages of re-assembly from a frame off resto. Also, my build is for a daily driver so, my thoughts were to make the truck 'bullet proof' because a DD has to be reliable. I've gone with the GMPP 350 RamJet, which is fuel injected. I like to shift, so I've got a 4 speed trans, and a 3:42 posi rear. 4 wheel discs with PS and PB. All lighting is LED. My thoughts when I started were to rebuild everything as though the truck had to last 20 years.
I forgot to add, if I could figure out how to post pics, I would!
#7 | |
I tried a couple of times to start a re-build record, but for whatever reason I can't figure out how to post pics. A few months ago I dropped a note to one of the mods, but never heard anything back. Anyway, I also did a rendering of what I wanted to build, I did a build 'spec', and I followed this site like it was the bible. Some of the members are very knowledgeable and will help with about anything. PM me with your email address and I'll send some pics. Jim
#9 | |
![]() Join Date: Mar 2011
thanks jz
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
Follow this about posting pictures and you should be ok.
http://67-72chevytrucks.com/vboard/s...d.php?t=501039 |
![]() Join Date: Jul 2013
Doing a LS swap is fairly involved. Unless you have a spare 10 grand you could order a LS3 (5.3 , LSA) E-Rod or and new 4L60E tranny. Then it will be much easier.
EFI is the way to go for mileage, but costly and technical. A good create engine like you mentioned is a great way to go with a 700-4R and 3:42's.
Mark Jesus is the Way! 2003 2500HD CCLB Duramax/Ali (Clifford) 2014 2SS/RS black on black Camaro (Betty) 2006 Pontiac SOLSTICE silver/black (Lula-Bell) 1970 C/10 Short Wide (Peggy) 1964 C/10 Short Step (Hambone) RIP Jimmy Hamilton Thank you for the trucks |
#12 | |
#13 |
Oh, yes. Lots of aftermarket stuff from Holley and Edelbrock. Also GM has the RamJet line of port injected Gen 1 small block create engines.
Doing a doner LS change is much more involved than doing a new GM create offering. Going with a new traditional small block is easy because everything is a direct fit.
#14 |
The initial cost of EFI is higher, but for day to day driving I think EFI is superior. The GMPP EFI engines have stand alone computers (ECU) that any GM dealer can service. There are after market EFI systems (FAST, Holley, Edelbrock) but, my research into those led me to think that I am not that knowledgeable about sensors, electronics, mapping, etc. to adapt one to a non-EFI engine. 'Universal fit' systems or parts rarely fit universally
![]() So, for my DD I chose an off the shelf 350 RamJet with the EFI package already to plug and play. No catalytic converter, nothing, plug and play. |
#15 | |
#16 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
When restoring a vehicle, if its made out of rubber or holds fluids in, change it. All of them.
Seals, hoses, gaskets, bushings, etc. Every one of them. You wouldn't trust a forty year old piece of rubber to serve as birth control. Don't trust one to work on your truck either. |
#17 | |
#18 |
It can be overwhelming if you look at it as a whole.
Break it down into manageable chunks. Front suspension and brakes Rear suspension and brakes Engine Transmission Convert to power steering if needed Add swaybar That way you can focus more closely. There is a lot of research on each phase. If you stay focused on a narrow part of the project you can fully research and grasp all of the information. I won't push my opinions too hard, but I'm a very diehard made in USA fan. There's still good parts out there on the market. You just can't always shop for lowest price. Sometimes you got to put on your big boys pants and pony up a few extra bucks for better quality. |
#19 |
My DD is not yet ready for it's road trials, so I'm unsure of MPG. Tex Firefighter has helped me with the motor install and is a valuable source of knowledge and info.
#20 | |
#21 |
Look at this project the same way you would eat an elephant. How is that? One bite at a time. Also beside the brakes suspension and god tight steering components are important as well. New brakes won't help you much is your skidding on the pavement with a broken ball joint.
Now moving on to the fuel injection, If you are a newer trucker lover with a lesser amount of wrench time, a ls transplant while worth wile is draining both your mind and pocket book. A crate 350 with a aftermarket EFI is very easy to install and easy to tune and will get decent mileage with the 700 and a 3:42 rear gear that would make a rock solid dependable truck. If a little more HP and TQ is in order you can stay basicly with that plan, but go with a Vortec [96 -00 gen 1 small block w/good heads] and a 4 bbl intake made for that motor [they are separate] and then add either an aftermarket hyd roller cam [cam only it is already hyd roller so just change the cam] and then put that aftermarket efi on there and it will awake a beast. The Vortec motor will add at least 40 hp over the regular 350 motor. Good luck with your project. Jim |
