What auto trans for a 8.1 vortec swap
Hey guys I'm going with an 8.1 vortec in my 72 4x4. I want to keep it auto. Would I need to look for a 4l80e from a 4wd truck or will the 2wd version work?
![]() Join Date: Sep 2005
Re: What auto trans for a 8.1 vortec swap
2wd will work if you want a 2wd drive only you'll need 4wd one
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
is there any way to make a 2wd trans work in my 4wd. my truck is 4wd right now
Is there a was? Yes, with the right output shaft and extension/adapter.
What transfer case do you plan to use?
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
Location: Sunny, Florida, some might call it South Alabama
Yeah you can make it work. But you have to change a few things. You should be able to google it.
Just sold my C10...sad day... Looking for a 1972 Blazer to hopefully fill the hole in my heart. |
![]() Join Date: Jul 2010
what trans is in it now?...you could jus have that one rebuilt..unless you jus wanna go with OD trans..
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
not sure what transfer case im going to use and right now i have a th400 but i do want to switch to the overdrive
If you don't know the difference between a 2wd and 4wd trans you probably shouldn't be attempting this swap on your own.
jon i never said i dont know the difference im trying to find out if i can make a 2wd trans work cause thats what i could get a hold of right now. and thats what forums like this are for bud to learn
I didn't mention, the output shaft replacement requires extensive tear down of the transmission.
meowMEOWmeowMEOW
I'll skip all the technical stuff.
Is it possible, yes. Is it practical, worth it, normal, or something that anyone here would have an interest in doing...no. www.car-part.com if you can't find a 4wd trans there, then your lying to me. ![]()
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
so im going to see if he'll sell the engine only and look for a 4wd 4l80e. thanks guys
#13 |
Truck and auto performance nut
I think they have a 4WD option......you could keep your turbo400 and put a Gear Vendors overdrive behind it.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
#14 |
meowMEOWmeowMEOW
or buy it complete and sell the 2wd 4l80e to someone else. The 2wd is technically worth more anyway.
#15 |
![]() Join Date: Jul 2012
#16 |
Newbee
Or you could get a divorced NP205, and a 2wd trans will work fine. Just another option.
