Dual Battery Tray Installation - Help! - Pictures?
No idea why I didn't take good photos, but my truck has dual batteries. When I blew it apart 2 years ago or whatever I guess I assumed I'd just "remember" the layout, but I do not.
There are a couple of things that move as a result, like the voltage regulator (or maybe it has two - I really don't recall). Can't find anything in the assembly manual, either. At this point I'd settle for a decent photo of an existing setup, but any help in finding a diagram, etc, would be very much appreciated. Thanks! Dave
![]() Join Date: Feb 2011
Re: Dual Battery Tray Installation - Help! - Pictures?
Here's a few
MusicMan70 1961 GMC Suburban |
![]() Join Date: May 2010
Take a look at post 6 in this thread. It's from the Blazer forum, but it sounds like this is from Pete's (DeadheadNM) K20. Post 11 talks about the voltage regulator mounting.
http://67-72chevytrucks.com/vboard/s...d.php?t=587742 And... post 8 in this thread shows a wiring schematic from the assembly manual. http://67-72chevytrucks.com/vboard/s...d.php?t=565859 Last edited by FirstOwner69; 10-29-2013 at 10:06 PM. |
This is driver's side. I hope this helps. Just putting my 71 back together and saw your post.
1964 C10... work in progress 1971 GMC 2500 Sierra Custom Camper |
Carpe manana
![]() ![]() Join Date: Dec 2010
Here you go - I've been through this twice now. Did you save the RPO specific washer fluid bracket that mounts on the RH? Good luck! Pete
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
Carpe manana
More...
Thx! I do not recall, and do not now seem to have, a second junction block on the passenger side. Going back to my original photos, there's only a single one. Truck is a Sierra Grande Custom Camper and the SPID has TP2. It was a one-owner-most-of-its-life and was almost completely unmolested. I don't even see witness marks of one being there before.
I do have the special washer bracket. Other than a fusible link between the two, it doesn't seem to serve much of a purpose (though that's a good one).
