Old 10-29-2013, 11:13 PM   #1
HotRodPayne
5.3 swap wiring question
do i need to use the big purple wire in the harness to the starter? cant i just use the original starter wiring front the factory harness to start the truck? i am using lt1swap.com while modifying my harness and i haven't read anything on the starter wiring. there is a picture on the site of a finished harness with the big starter wire rolled up and labeled. it has me confused. go easy on me this is my first time doing anything like this.
HotRodPayne is offline   Reply With Quote
Old 10-30-2013, 12:26 AM   #2
71chevystep4x4
71chevystep4x4's Avatar
Re: 5.3 swap wiring question
Just use the original one in your truck, I did the lt1swap.com harness mods as well, and everything turned out great.
71chevystep4x4 is offline   Reply With Quote
Old 10-30-2013, 12:32 AM   #3
HotRodPayne
Ok great. Thanks. I've been stressing over this wiring!
Old 10-30-2013, 06:41 PM   #4
Billett
Billett's Avatar
I cut the purple wire to the starter inside the cab. Because the harness I got from CPP has a wire that runs into the cab for the ign I just connected it there and then used the purple wire with a fuse for my oil pressure gauge since it was already run through the firewall and in that direction.
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 10-30-2013, 06:42 PM   #5
Billett
Billett's Avatar
Don't quote me on the ign connection inside the cab, but I know for sure I cut it and used it for the pressure gauge.
Will
2024 Toyota Sienna
Old 10-30-2013, 07:32 PM   #6
Blackpony
Blackpony's Avatar
I added a wire to my harness that goes to the starter and added a weather packed connector and attached it to the factory starter wire on the truck. Basically using the factory stuff just hiding the wire in the harness for a cleaner look.
Blackpony is offline   Reply With Quote
Old 11-01-2013, 10:04 AM   #7
Houston Ben
Houston Ben's Avatar
When my harness came back I hooked the purple wire to the OG ingnition wire for what it's worth.
Houston Ben is offline   Reply With Quote
