Old 10-30-2013, 12:01 AM   #1
SKELLY4x4
SKELLY4x4's Avatar
hydro boost?
Has anybody done the hydro on a 67 to 72? Mine is ripe as the p/s pump is a hydro from that era with a blocked off hose that would go to the hydro boost. I heard there are conversion kits but they are expensive as hell. I replaced the one on my 2001 and it was half the price. Not sure about mounting. Thanks and cheers!
1972 chevy k20 long bed 4x4
1990 chevy K5 blazer
2001 chevy 2500 hd 4x4
1999 chevy 1500 4x4
SKELLY4x4 is offline   Reply With Quote
Old 10-30-2013, 12:29 AM   #2
eagleuh1
eagleuh1's Avatar
Re: hydro boost?
I did. I used a Tallon Hydraulics adapter plate to mount to the firewall. Wouldn't do it if you have a shifter cable from Lokar, the hydraboost interferes with in the position originally used by the adapter plate. I modified my plate by filing off the lock tab and rotating the hydraboost back to original orientation. filing a groove for a lock key to keep the hydraboost from rotating. I used 73-85 diesel pickup with hydraboost hoses and modified the end to the steering gear box. Put a flare nut with a flare on it to mate to the 68 C20 steering box. All other hoses fit with minor bending. I used a 85 power disk/drum brake master cylinder. Had to cut and weld on a homemade shackle to the hydraboost piston rod with a threaded extension that mates to my brake pedal. You might be better off using CaptainFabs booster bracket and adapter. My hydraboost got from a 2004 2500 GMC at junk yard. Its leaking power steering fluid now. So will have to pull and rebuild soon. Will get some pics tomorrow if I can remember. Good luck with yours. Jim
eagleuh1 is offline   Reply With Quote
Old 10-30-2013, 12:30 AM   #3
eagleuh1
eagleuh1's Avatar
Re: hydro boost?
PS. My 68 C20 has a 2005 5.3 with hydraboost power steering pump.
Old 10-30-2013, 10:40 AM   #4
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Re: hydro boost?
I happen to have a unit from a 93 Suburban 2500 complete that I'll willing to let go of. PM me to discuss
Steve
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2019 GMC Diesil Dually. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 10-30-2013, 10:46 AM   #5
LockDoc
The Older Generation
LockDoc's Avatar
Re: hydro boost?
Originally Posted by SKELLY4x4 View Post
Has anybody done the hydro on a 67 to 72? Mine is ripe as the p/s pump is a hydro from that era with a blocked off hose that would go to the hydro boost. I heard there are conversion kits but they are expensive as hell. I replaced the one on my 2001 and it was half the price. Not sure about mounting. Thanks and cheers! '
For some good reading type the words "hydroboost" into the GOOGLE search box at the top of this page, click on the circle in front of "67-72chevytrucks.com" and click on the GOOGLE button. You will find lots of threads on the subject. Just make sure the thread you are looking at refers to your style of truck. (Hits will include all years)
After you read through all of those threads then type in "Hydraboost" and you can read a bunch more...
LockDoc
Leon
Old 10-30-2013, 10:49 AM   #6
68 Longbed Dan
Re: hydro boost?
I took a Hydro, front crossmember, control arms and disc brakes off of an 80's diesel (5x5 bolt pattern) and bolted it all right up. Took the rear end too and removed the old spring setup and made it work with my trailing arm setup. Might be able to find a junked truck to pull it off like we did.
Dan
1968 Longbed Stepside C10
68 Longbed Dan is offline   Reply With Quote
Old 10-30-2013, 08:08 PM   #7
eagleuh1
eagleuh1's Avatar
Re: hydro boost?
Pics as promised.
Old 10-30-2013, 09:33 PM   #8
mmiddle
mmiddle's Avatar
Re: hydro boost?
Check this out... This guy is located just North of Denton, Texas (North of DFW)
http://www.ebay.com/itm/300912674354...84.m1423.l2649
It's a direct bolt on
Mark
Jesus is the Way!
2003 2500HD CCLB Duramax/Ali (Clifford)
2014 2SS/RS black on black Camaro (Betty)
2006 Pontiac SOLSTICE silver/black (Lula-Bell)
1970 C/10 Short Wide (Peggy)
1964 C/10 Short Step (Hambone)
RIP Jimmy Hamilton Thank you for the trucks
mmiddle is offline   Reply With Quote
Old 10-31-2013, 01:02 AM   #9
SKELLY4x4
SKELLY4x4's Avatar
Re: hydro boost?
Lot's of good info here in this thread. I like the kit with everything from BROTHERS but it's spendy. I'll check out the suggestions listed and go from there. That stock hydro setup on my 2001 burb and 2500 truck are awesome and it would be a shame not to put it on the old yeller. cheers yaall!
1999 chevy 1500 4x4
Old 11-01-2013, 12:50 AM   #10
eagleuh1
eagleuh1's Avatar
Re: hydro boost?
The hardest part of the job was disconnecting the brake pedal rod between the vacuum booster and firewall. And getting my fat head up under the dash to see the brake pedal . As stated in prior post. If you can find a donor with all the bake components, pumps,hoses ... from 73-85 it makes it real easy. Good luck with yours. Jim
