70+ ( Old Skool Club )
![]() Join Date: Nov 2003
BB Intake Casting Number
Where is the casting number on the intake located on a 396 BB engine. I'm thinking it must be near the back around the distributor becuase I havent found it near the front. If someone could a picture I'd appreciate it.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
Re: BB Intake Casting Number
I'm thinkin' right in front of the carb. flange. Is it iron or alum.? Don't have any factory ones but several good pictures on EBAY.
Dad always said, "Son, WISH IN ONE HAND, and ......." -------------------------------------- -------------------------------------- Current toy trucks: '71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C '72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these: '66 Plymouth Belvedere City of Miami cop car clone. '70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!! '67 C10 short/step side mount spare -- SOLD!! '72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!! '69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!! |
I didn't see it near the front of the carb when I checked it initially, but these old eyes have been known to miss the odd detail the last few years. Its a stock cast iron GM manifold. The pic is of my engine.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 Last edited by Already Gone; 10-30-2013 at 08:20 AM. |
That looks like a later model 454 engine with an aftermarket or hi-rise intake thats been painted.
Thanks for your input. I did get the block casting number from the block when I first bought the truck and the casting number is for a 396 from 1967 with a 2 or 4 bolt main. I checked the exhaust manifold numbers and they are from a 1973 Police 454 engine. I've never had a valve cover off so I don't have the casting numbers for the heads. Do you think my intake may be aluminum ?
Roadtrip!
![]() Join Date: Feb 2003
Casting number is between the carb and dist. Get the number and date code and i can look it up for you.
Take a magnet and stick it to the intake and you will know if it is cast or not. Eric
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
That is why I didn't see the number. The magnet idea is great.
I got the casting number off the cast iron ( the magnet worked ) intake manifold today. It is 3883948 and I didnt see a date code. My engine number is 3902406 and the exhaust manifolds are 353030 on the passenger side and 3994045 on the drivers side.
I guess all I have to do one day is get ambitious and pull a valve cover to get the casting number for the cylinder head.
Based on the site pasted below the intake is a factory hi rise for a quadrajet carb. It was used on several different cars. Based on the engine casting number it could be original to the engine, that would be my assumption anyway:-)
http://www.lbfun.com/warehouse/tech_...%20Numbers.pdf |
Florida Edition
![]() ![]() Join Date: Oct 2010
Yep, 66-68 Oval Port Q-Jet
396-325HP L-35 or 427-385/390HP L-36 Car engines.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
I bought the truck with the engine in it. I was told by the seller that the truck had a 396 which it does and had been recently rebult which ( by the way it runs ) I believe. Apparently the engine was from a Chevelle and was going to be put back into the Chevelle but the guy ran into hard times and sold it to the owner of the truck before me. Now I'm motivated to yank a valve cover and get the number of the head.
