What about bags?
So I got this idea about running bags up front only on my 69 c10 for adjustable ride height. My original plan was to have a track only truck, but I had an idea of making it street worthy too. Is it possible to run bags at the drag strip?
Only problem I can think of is that my truck might just lift the wheels off the ground and when it lands, it may just blow the bags out. Anyone see a problem with it? |
Registered Truck Offender
Re: What about bags?
I think there is probably a good reason you don't see air bag suspension at the track. Blowing the bags I don't think would be an issue, it's the lack of stored energy would be pretty counterproductive at the track IMO.
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
What do you mean by stored energy?
It has to do with weight transfer from front to rear. Someone will chime in with more info but this is a good read regardless:
https://www.cachassisworks.com/Attac...1-226_drag.pdf Edit: Look at page 5
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
In simple terms,, a 1500 pound load on a front suspension spring, has 1500 pounds of 'lift' wanting to be released as the leverage of the tire / torque removes that weight.
It wants to 'help' the leverage of the suspensin take the weight off the front, and put it onto the rear.
Oh,, and a spring will have a LONG travel to release that 1500 pounds, where a air bag will only have a very few inches of travel to release all of it's 'stored energy'
That make sense?
So you're saying that by having bags in the front, there is less energy being stored than there is with springs/shocks resulting into less front end lift also resulting into less weight being put on the rear end for a loss of traction?
I think I'm beginning to understand. So for a shock that has a lot of travel, the front end weight will lift higher putting more weight on the rear rather than having a bag and only a little travel for not very much weight transfer? |
#8 | |
2. I assume you mean spring? Yes, typically you need a softer (as it will be longer) spring to maintain a good ride height
Yes I meant spring. Makes sense for why there isn't bags at the track.
What about those adjustable springs. Wouldn't I be able to set them up for track use and then for the street, turn them a little and lower the front of the truck? Or vise versa? |
Adjustable springs? as in coilovers? yes but there arent really coilovers for our trucks unless you do a porterbuilt/scotts/etc set up
Here's a picture to do the 1000 word thing.. A full tilt drag race front suspension/spring (and this is just a 2600 pound car) look at the length of the spring to hold up a very light car. I put travel limiters on it to limit the rise and try the limit the wheelstands.
Where an airbag has a whopping ,,, what 3" maximum travel to unload ALL of it's support. You commonly find airbags in the right rear coil spring as a chassis tuning aide to help plant both tires evenly. But as a suspension... there better left to the slammed street crowd just imo
![]() Join Date: Mar 2008
Marv that was a good post. Now give us some launch pics like the one in your YB avatar. The Chebby Too is cool!
NHRA Super Street 469C It only runs 10.90 at 156 mph |
#13 |
Lol., here's the 'airtime' video that avatar photo came from I think.. she used to get up on the tire just a bit.
http://www.youtube.com/watch?v=0BDdg...ature=youtu.be Man that is SOOOooooo hard on parts! Sparks was a few gouges in the oil pan and header extensions. I had to try and stand the tires back up straight in the stock Chevy II front suspension after every race. (Hence the AJE strut front clip added in the pic above)
#14 |
Not sure if any of you have seen this thread, but I've been reading through it and gave me an idea for the adjustable coil overs up front. You guys think it will work for racing purposes?
http://67-72chevytrucks.com/vboard/s...d.php?t=266485 |
#15 |
Anything can work with enough fab. Do you need to make adjustments? Are you planning on driving it on the street and need to preform really well at the track? It seems like a lot of work to me. You can also buy new springs that are longer and softer that will do the job and ride decently on the street.
#16 | |
#17 |
Any more input?
#18 |
Boosted Member
My street truck ran high 11s on bags all the way around. How fast are you planning to go?
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
#19 |
I want to get into mid 10's at the fasted, but I want to lift the front wheels off too just a little bit if possible with zero fiberglass
