Old 10-30-2013, 11:29 AM   #1
Mick65
Swap Saginaw 4 speed manual for 350 Turbo Auto
Thoughts? The guy has a brand new 350 turbo still in the box. He's asking $500 for it. Seems expensive to me.
Would it bolt up directly to my 65? I have a small block in it now. What else would I need to make the swap work? Should I keep my eye out for a different type of transmission?
Thanks!
Mick65 is offline   Reply With Quote
Old 10-30-2013, 12:41 PM   #2
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: Swap Saginaw 4 speed manual for 350 Turbo Auto
I'm just picked up a th350 that I'm going to swap out my 4-speed sm420 this winter.
I'm rounding up the parts now.
I found several threads in these forums on the topic.
If I had the money, I'd probably go with an auto that has an overdrive.
I don't have the money, and I don't drive my truck much, so the th350 should be fine for me.
66 C20 Service Truck:
Old 10-30-2013, 05:17 PM   #3
kieth
kieth's Avatar
Thanks!
If you are going automatic I would go with a 700r4, if you will send me your current tire height in inches from the ground to the top of the tire and your current rear axle ratio I will send you a spreadsheet that show speeds and torque to the ground........also your engine.....this way you can see how your truck will perform before you do it.........send me your email in a private message on this board (cannot send it any other way) cannot post it on the board must email it to you. Kieth
kieth is offline   Reply With Quote
Old 10-31-2013, 12:30 AM   #4
Captainfab
60-66 Nut
If it is a quality rebuild, $500 is not out of line. The cheapest price I have found is $650.00 with a converter, and not including a core charge.
