Old 10-30-2013, 12:13 PM   #1
Branman1971
Branman1971's Avatar
Headers or Manifold?
I am cleaning up the motor and tranny for paint and I am considering replacing the crappy looking exhaust manifolds with some headers but they seem hard to find a set that will go on a 350 and clear the crossmember on a 61. There are many affordable sets out there though. I see a bunch of you guys have them so can anyone recommend a set that will bolt on my 350 and not set me back too much $$$? Thanks.
Active duty Navy CPO
1961 C10 SWB
1963 C10 LWB (donor)
1965 C10 LWB BBW
Branman1971 is offline   Reply With Quote
Old 10-30-2013, 07:24 PM   #2
LVPhotos
LVPhotos's Avatar
Re: Headers or Manifold?
I used Patriot shorties on my '62. Could use mid length as well.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 10-30-2013, 07:25 PM   #3
LVPhotos
LVPhotos's Avatar
Old 10-30-2013, 11:54 PM   #4
MisterC
MisterC's Avatar
Look at the Speedway motors manifolds. Dino uses them on all of his builds and swears by them.
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline   Reply With Quote
Old 10-31-2013, 12:16 AM   #5
Branman1971
Thanks guys. I will check em out!
1961 C10 SWB
1965 C10 LWB BBW
Old 11-12-2013, 09:33 PM   #6
Branman1971
I don't think that my old manifolds are usable. Each manifold is missing at least one bolt. I think they are pressed in because the bolt holes do not go all the way through. I am still looking for some used headers but I wanted to ask you guys if I am correct. Thanks!
1961 C10 SWB
1965 C10 LWB BBW
Old 11-12-2013, 09:36 PM   #7
1963c-10
1963c-10's Avatar
hedman headers HED-69620 $179 new in the box through SUMMIT for sbc trucks
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 11-12-2013, 09:39 PM   #8
Branman1971
Thank you. Do you have them? Do headers affect the sound or just performance?
1961 C10 SWB
1965 C10 LWB BBW
Old 11-12-2013, 09:45 PM   #9
1963c-10
1963c-10's Avatar
Im in the process of a big block build right now. Just happened to have the Summit catalog open to exhaust as I've been debating header wrap or not...they show a hedman header for 55-65 chevy trucks 283-400 sbc 1 1/2" od 3" collector. I don't know how they'll modify your exhaust tone, but they are louder than most stock manifolds, flow better and you will notice a difference in the performance of the engine if its all running right. Im using Hedman headers on by bbc build and I have used them in my 69 chevelle SS and a prior 63 c-10 I had. Ive always liked the quality of them.
You should be able to get online and find a video of them in a similiar set up for sound.
If you have any question on fit, I'd contact the tech's at Hedman...they advertise it to fit so they should guarentee.
Old 11-12-2013, 09:57 PM   #10
Branman1971
Great! The price is right too. I had Blackjack headers on my 69 Chevelle but never heard it with manifolds. I think those are more pricey if I remember right. Thanks guys!
1961 C10 SWB
1965 C10 LWB BBW
Old 11-12-2013, 10:48 PM   #11
Branman1971
And made in the USA to boot!
1961 C10 SWB
1965 C10 LWB BBW
Old 11-12-2013, 10:57 PM   #12
Reyals Bemus
I run the Speedway Motor's Tru-Ram manifolds. They are outstanding! All the reliability of cast iron manifolds, with the flow of shorty headers, minus the tinny sound that some headers can have. They are not cheap. $300 for the reg. iron manifolds, $400 for unpolished stainless, and $500 for polished stainless. You get what you pay for though. I bought the regular cast iron ones and coated them with KBS XTC high-temp paint. Total nuclear longevity now.
I can get a pic of them in my truck if anyone is interested. Clearances are perfect around everything.
Reyals Bemus is offline   Reply With Quote
Old 11-13-2013, 01:34 AM   #13
Captainfab
60-66 Nut
Those broken studs in your manifolds are not pressed in, they are threaded. However with old rusty and crusty manifolds, the broken studs can be a real pain to get out. They usually require the heat of a torch and sometimes a welder to get them out.
The part number for the Hedman headers you need are #69260's
Old 11-13-2013, 08:11 AM   #14
davbowen
davbowen's Avatar
just installed Summit Racing G9006-9 Headers. ceramic coated. fit like a glove.
davbowen is offline   Reply With Quote
Old 11-13-2013, 06:30 PM   #15
Branman1971
Do you have a 350 Davbowen?
1961 C10 SWB
1965 C10 LWB BBW
Old 11-13-2013, 07:50 PM   #16
davbowen
davbowen's Avatar
yep. 350 w/th350 in my 63. headers clear motor mounts by a least 1/2". they do hang below the frame some, but i'm not slammin it. have 4.5"/7" drop when done.
Old 11-13-2013, 08:06 PM   #17
NEWFISHER
NEWFISHER's Avatar
Originally Posted by reyals bemus View Post
i run the speedway motor's tru-ram manifolds. They are outstanding! All the reliability of cast iron manifolds, with the flow of shorty headers, minus the tinny sound that some headers can have. They are not cheap. $300 for the reg. Iron manifolds, $400 for unpolished stainless, and $500 for polished stainless. You get what you pay for though. I bought the regular cast iron ones and coated them with kbs xtc high-temp paint. Total nuclear longevity now.
+1
NEWFISHER is offline   Reply With Quote
