Old 10-30-2013, 03:09 PM   #1
Jon01
Jon01's Avatar
99 LS1/4L60E, set up for standalone
I have a friend selling the LS1 out of his 78 Delta 88.
It will come complete with the modded harness, fuse panel, intake ducting, f-body headers and everything you need to do a standalone swap.
Motor has about 90k on it, trans is a low mileage GM reman.
Mods:
LS6 intake
LS6 heads - cut .015 for compression
TSP Torquer 2 cam
PRC duals/Ti retainers
Comp pushrods
LS7 lifters
LS2 timing set
LS6 oil pump
New gaskets top to bottom
Circle D 3200 converter
Transgo shift kit
Tune is done, VATS deleted, etc...
If you know what gear/tire you're going to run on your swap I can reconfigure output so you won't have to do anything with the tune once installed - hook up power, grounds and hit the key and it will light right up.
All you would need with this setup is a fuel pump, electric fan and driveshaft. Otherwise it's a complete ready to run standalone LS swap.
It's still in the car, if you're close and want to come drive it you're welcome to do so.
He's looking for $6,000.
When you price a dropout(3k), add up all the harness, mods, etc...you'll see you're serious $ ahead.
Shipping is entirely at your expense.
Jon01 is offline   Reply With Quote
