Old 10-30-2013, 06:14 PM   #1
marvgarr68
marvgarr68's Avatar
ammeter millivolts
Does anyone know what millivolts the ammeter is on a 68 c10. Im changing the wiring and I know the long 12g red wire is a shunt and I want to remove this wire and install a bigger wire. If I know what millivolt the gauge is I can put a shunt on the battery feed wire I will be running which is a 4g cable. I need this because the alt is a 100 amp plus there is a lot of current going through that little 12g wire and a lot of voltage drop.
1976 k20, 350 built, 44/14 axles
1968 c10 6.5 turbo diesel,t5 trans
1977 gmc c3500 dually, crew, 4-53t, 5&3 trans
http://67-72chevytrucks.com/vboard/s...d.php?t=591188
marvgarr68 is offline   Reply With Quote
