But Found Her 25yrs Later!
![]() Join Date: Oct 2010
If someone knows how to repair aluminium....
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
Re: If someone knows how to repair aluminium....
Hate to say it, but I think that one is toasted.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
![]() Join Date: May 2007
LT1 burb was looking for one, but I think some guys convinced him rough ones only cost 50 bucks...
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
I think someone with good welding skills could fix this one.
60-66 Nut
![]() ![]() Join Date: Mar 2007
The best way to fix that one, would be to weld in a new piece in that real bad area. Of course you would have to either form a new piece, or cut a piece from another '63 aluminum grill. If the headlight bezels were included, it might not be a bad deal.
four words
puh puh puh pass |
Yeah that one is too far gone. I almost bought a truck that had a perfect aluminum grille on it but didn't want to part another one out.
![]() Join Date: Mar 2005
The problem with trying to repair a factory aluminum grille is that they are very soft, and when they get hit hard enough to dent it, the metal stretches to a point where it won't go back into shape. If you're lucky and you can get it pretty straight and all you have to do is weld in a donor piece, you have to be really careful. Welding in a section is tricky because it's really thin and soft, and you're almost guaranteed that you'll have a section that'll discolor from the heat. When it's re-polished, you might not be able to get those sections to polish clearly. Meaning, they still might show a white or bluish cast from the heat of the welding. Sometimes, you get lucky and they buff out. If the price was cheap, it might be a good grille to play with. It would take a lot of work, but it might turn out decent.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
