10-30-2013, 07:15 PM | #1 |
How many of us are "taking a break?"
With winter coming, I will basically have to stop working on my truck till spring. It's in my garage but about all I plan to do to it now is remove the remaining tack welded cab bolt and maybe replace those bushings (finally). My garage isn't heated so doing much at all will be very difficult.
Is anyone in the same boat? |
10-30-2013, 07:33 PM | #2 |
Re: How many of us are "taking a break?"
Winter in michigan. Nice pole barn. No heat or electric.
10-30-2013, 07:40 PM | #3 |
I sent mine to paint jail for the winter. Can't bother it there. I guess that's a break.
1972 Chevy LWB Roadster 1999 Chevy Silverado 2wd 2015 Chevy High Country 4x4 Crew Cab |
10-30-2013, 07:51 PM | #4 |
I'm taking a break because i'm pissed at my brakes... About ready to have it towed to a shop! LOL!
I normally still tinker with it thru the winter tho, but under a 20X10 car cover
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
10-30-2013, 07:53 PM | #5 |
Winter is the only time I can work on my autos in the garage summer is way to hot and I can bundle up in the winter and a small propane heater helps also.
10-30-2013, 08:00 PM | #6 |
I'll spend the winter doing rust repair and suspension work. The great thing about Texas winter is that one day it might be 35 the next 75. Some days its both.
Mark Jesus is the Way! 2003 2500HD CCLB Duramax/Ali (Clifford) 2014 2SS/RS black on black Camaro (Betty) 2006 Pontiac SOLSTICE silver/black (Lula-Bell) 1970 C/10 Short Wide (Peggy) 1964 C/10 Short Step (Hambone) RIP Jimmy Hamilton Thank you for the trucks |
10-30-2013, 08:03 PM | #7 | |
I live in Kansas and we get our share of cold weather. I have one of those little electric heaters that you buy at Wal-Mart for 20 or 30 bucks. As long as it's not blistering cold, that little heater and a sweatshirt keep me just fine.
Willie Swamp Angel Truckers '72 C10 Highlander People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. |
10-30-2013, 08:32 PM | #8 |
You girls put them away huh?
I put the most time on my truck in the winter. Note I said time as I don't get many miles pushing snow around the driveway or driving out to the fish house. Just kidding on the girl comment. Remember, snow doesn't hurt a vehicle. Salt does however. I keep my truck off the roads in the winter which keeps the salt off of the truck.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
10-30-2013, 08:36 PM | #9 |
its 75 and sunny here today. I finally got a call back from the mobilehotrod mechanic so Im taking my truck out there next week for rockers and floor work.
theres no rest for the wicked |
10-30-2013, 08:54 PM | #10 |
Like mmiddle said the temps can vary so much here in North Texas, so putting away the toys for the winter isn't really necessary.
In fact it can be perfect time and temp to get a lot done. Just need a wind proof shop a nice heater some of the time, and of course plenty of Shiner Bock to enjoy while working on the toys.
1972 Chevrolet Cheyenne LB 1/2 ton finished restoration/rebuild 1995 350 throttle body FI, 4L6E (running on modified GM wiring harness) 3.08 posi rearend, factory A/C on 134A, p/s, p/b, late 70's power windows and locks and cruise, speakers in the dash + 6x9's behind the seat, factory tilt, 40 gallon fuel tank in the bed with integrated tool box, air assist bags on the rearend, sway bar up front and much more. 1972 chevrolet SNB finished 2002, 350 TB FI, TH400, factory A/C, p/b, p/s, (FOR SALE) 1969 Chevrolet 1 ton in work, home made PTO dump bed extended frame, 350 CI , 1972 Chevrolet 3/4 ton suburban future project 1972 Chevrolet 3/4 ton p/u maybe a project one day 1966 Toyota Landcruiser my playtoy |
10-30-2013, 08:57 PM | #11 |
Its down to 30 degrees here already so I go out to the garage and set the thermostat to 65 degrees and in the spring I will turn off the heat. Where the heck am i suppose to entertain myself for six months.
Fuzzy |
10-30-2013, 08:59 PM | #12 |
If there are no wrecks for me to work on [witch is very very rare] I rarely get to put in more than a couple of days in a row together on any given truck project. What I have been doing however is doing body work on a panel here and there when I have a spare morning or afternoon,something like that. I have one truck that is out getting the test driving stuff done[I always drive them to check them out, most of the time before paint if it was a big build to check and make sure that there won't be a bunch of fender leaning going on. Well I sold the truck the guy likes it so much he is just driving in prime and will turn it loose to paint sometime. This is leaving an empty shop so I can even put one of my old trucks inside the shop been close to six months since that has happened. I have even got to work on it about a week now and am making progress. I have the bedsides split apart so i could do some dolly work on each side that had a weird dent I figured the best way. I also just about got the floor ready to prime I've been hammer and dolly working on it, it is in real good shape maybe the best of the three I'm doing. Doing a panel here and a panel there type work may seem like your not getting anywhere but I almost have the body work done to do two of the three trucks when I do start the frame off on stuff they will build rather quick with all the parts primed ready to go. Jim
10-30-2013, 09:01 PM | #13 |
so if I get a chance to work on them because of the others that come in the shop I take the opportunity, cause I don't know when I might again. A transport load of wrecks may be on the way from the sale just about any given sale day. Jim
10-30-2013, 09:04 PM | #14 |
US Army Veteran
70 degree days here in Southwest Texas. It's like free air conditioning.
I generally tend to take breaks in the summer here. The heat is overwhelming. It did freeze here pretty bad about two years ago during the winter. Our water pipes in the home froze up for two days. For the most part, though, it's pretty mild and my favorite time of the year to get work done.
1972 C10 Highlander - The making of a daily driver |
10-30-2013, 09:27 PM | #15 | |
10-30-2013, 09:31 PM | #16 |
70+ ( Old Skool Club )
Mine is already tucked away for the Winter. The garage where I store the truck is not insulated or heated so working on it with the winters we get up here is not an option. Its kinda nice every Spring as its warming up outside and I get the truck out and start doing the things to it I thought about all Winter.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
10-30-2013, 09:33 PM | #17 |
The "girl statement" is very sexist. I may have to report you.
Seeing that 69/70 plowing snow is awesome! I have considered starting something like that but for hire. I have the room in my driveway for a plow and I could make the time. Last edited by In The Ten Ring; 10-30-2013 at 10:04 PM. |
10-30-2013, 09:38 PM | #18 | |
84 step side 87 swb |
10-30-2013, 09:42 PM | #19 |
10-30-2013, 09:51 PM | #20 |
I will drive mine everyday all winter.
10-30-2013, 10:07 PM | #21 |
Eh. Don't let winter stop you from working on your truck. Especially not where you've got a garage. I got a lot done on my truck this past winter....without a garage
10-30-2013, 10:13 PM | #22 |
as long as the weather is not too bad then I will still piddle with the truck. Last yr I got more done in the winter than summer, we had a lot of rain this yr..I don't have a garage.
1964 BBC 402 4x4 |
10-30-2013, 10:27 PM | #23 |
I'm just glad it's not 120º in the shade anymore.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
10-31-2013, 12:29 AM | #24 |
Well I work most days during the winter, usually 12 hour days so I don't have a lot of spare time. Toss in grad school, my business, and trying to write a novel and time is short.
Besides, my garage is very small, and the next job is removing the front clip and no way I'd try to store those parts outside (no room inside the garage) so it'll have to wait. If I can replace the cab bushings it'll be enough. |
10-31-2013, 12:30 AM | #25 |
That little 20-30.00 heater burnt my step dads rental trailer down this past weekend. Please be careful with it
