10 bolt posi clutches
Where can I find replacement posi clutch discs for my 86 factory posi in a 8.5 10 bolt? Last time I had the cover off I found a partial disc and a partial ring gear tooth in the bottom of my pumpkin. I got some nice richmond 4.11 gears to put in but I need to fix the posi clutch packing at the same time.
Re: 10 bolt posi clutches
Pictures? Clutch-style traction devices are not factory equipment in our trucks. The Eaton G80 or Gov-lock is standard and it does not have clutches...it can grenade and shed parts, but not clutch material.
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 |
Well that changes thungs then lol I don't have it apart now nor am I in a position to since its almost winter lol the spid said posi 2.73 its 3.73 now. I thought the gov locs were clutch pack type.ill have to research more.
Look up the G80 or Eaton Gov-lock on youtube, there are some good animations and how-it-works videos.
Still uses clutches I'm pretty sure.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
I stand corrected, it has a clutch system as part of it's mechanism. I should have stated that better, it is not a clutch-type posi as can be commonly found.
Eaton G80 vs. Eaton Posi (clutches)
So I'm familiar with how the g80 in the 90s worked with the centrifugal cams that locked it up I though the earlier ones were clutch packs. I guess ill have to pull it apart n get pics or look closer at the carrier for info unless there's one type of clutch carrier that used stacked clutch plates
Its been 2 years since i opened up the pumpkin but i recall it looking like what ive found to be the corporate type O gm posi with the S spring like what the grand nationals used.gm discontinued those clutches a while ago however I found some they just started reproducing. http://www.gbodyparts.com/product_in...oducts_id=1813
Thought I'd share |
