Old 10-30-2013, 10:51 PM   #1
draimondi
79 Factory Tach Help
So, my original factory tach hasn't worked in probably 20+ years. When i finally decided to take it out and try to find out why some diodes on the board seemed to be burned up. I found another 79 truck today with a factory tach and was told it worked fine up until the time it was parked, which may have been quite some time ago. Is there any way to bench test these tachs to ensure they work before installing? Any help is appreciated!
draimondi is offline   Reply With Quote
Old 10-30-2013, 11:31 PM   #2
83GMCK2500
Re: 79 Factory Tach Help
Three lengths of wire, 4 female spade terminals and two alligator clips should get the job done... There is a diagram around here somewhere, but the tach connects to a ground, key-on power, and the tach signal at the HEI distributor.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is online now   Reply With Quote
Old 10-30-2013, 11:49 PM   #3
draimondi
Thanks! Doesn't sound terribly difficult. I'll see if I can find the diagram on here. If anyone finds it before I do please share.
Old 10-31-2013, 09:47 AM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
mine first wasn't stock in my 78,
used this to ease in/out
great for testing,and i can plug this one back in to use under the hood
hooked to the cluster power,(not threw the firewall like stock would be)
pink/black is power
black is ground at the Ebrake ground bus
and mine used a brown wire for the signal to cap(some are white)
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
