Old 10-30-2013, 10:55 PM   #1
mountainman1
1970 GMC JIMMY 4" lift or 6"?
does anybody have suggestions regarding using a 4" or 6" lift to fit 35x12.5R17 tires? i am planning on using reverse shackles (good for 4" of lift) from Off-Road Design for the rear suspension but if a 6" is necessary i will order rear springs with extra 2"
mountainman1 is offline   Reply With Quote
Old 10-31-2013, 01:06 PM   #2
pound41
Re: 1970 GMC JIMMY 4" lift or 6"?
getting ready to put 4 in lift on my blazer. I am getting a 4in front and rear leaf spring kit from BDS. Only reason for BDS is a high end local shop only uses them. So the price is comparable to the others. It has 6 in lift on it now and its stiff. Shakes your teeth
pound41 is offline   Reply With Quote
Old 10-31-2013, 01:35 PM   #3
cleszkie
cleszkie's Avatar
From my experience, if you plan on taking the Blazer off road at all, go with a 6" lift. Otherwise, you will get rubbing on the front fender during full lock turning and minor compression. If cruising on the street is all you do, a 4" lift will clear the tires.
If you want a softer ride than most 6" spring lifts will give you, try Skyjacker "Softride" springs. They have more leaves per pack, but the leaves are thinner.
cleszkie is offline   Reply With Quote
Old 10-31-2013, 06:32 PM   #4
Chulisohombre
Chulisohombre's Avatar
4 inch front plus ord extended shackles. Gives you 4.5 inch lift in front and the lift kits come with a 6 inch rear for first gen blazers. That way it gets rid of saggy butt rear end. So go with the shackle flip with 2 inch lift springs. Youre going to need to either shim the axle or cut a reweld the perches to get the ujoint angles correct. That or a cv rear shaft if it has vibration. That's what I have with 35x12.5 tires and no rubbing. The rear end sits slightly higher in the rear but with the top on it sits pretty level. I have a double wall so it's fairly heavy and compresses the rear springs so it sits nice. I also trimmed the front fang back a bit also on the fenders.
Chulisohombre is offline   Reply With Quote
