inferior rag joint?
Guys
I bought a rag joint from a reputable vendor that a lot of guys recommend here. The rag joint has regular bolts going through the rubber, where as better rag joint have the collared bolts (see thread below) http://www.camaros.net/forums/showthread.php?t=113278 Have you guys ever used the rag joints with the regular bolts? Any problems with the install or later on? Wondering if i should get the collared bolts or a better rag joint thanks guys |
![]() Join Date: Feb 2004
Well if you are running manual steering loose the rag joint and get a grand cherokee shaft bolts right to the box and very little grinding on the column side and is much tighter and better feel not to mention it has double u joints
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
Re: inferior rag joint?
nope... running power steering
thanks though! |
I'm just glad to be here!
I will be doing a swap using a Jeep Cherokee (not Grand Cherokee) intermediate shaft to replace the section between the column and the power steering box on my C20 truck. I got the shaft at the pick a part for $20. The replacement rag joint was much more that that. I hope to work on it this weekend. I will post a how too once I get it done.
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
X2 on the NOT Grand Cherokee.
Not trying to hijack... figure i ask since we're on this topic, but is there a difference in the different year model on the rag joints?? or is it the same throughout 67-72??
Thanks, Wayne
1970 Chevy K20 Custom Camper 1996 Chevy Impala SS 2008 Chevy Avalanche LT3 2003 Honda Accord EX 2001 Hewes Redfisher 16 Fighting Lady Yellow Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=324118 |
i believe the rag it self is the same but the metal section that mounts to the gear box is different for power or non power the grand cherokee shaft is a direct bolt on for non power. From the other post maybe the regular cherokee works for power not sure. But mine was 93jeep gc
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS Last edited by Robznob11; 11-06-2013 at 12:10 AM. Reason: miss type |
