Old 10-30-2013, 11:36 PM   #1
jbassC10
Question 71 Spindle Lock Nuts? Where can I find them?
Autozone/O'reily's* are letting me down. I've searched and hit store after store and the only two anwsers I've been given are: "junk yard, or call a GM dealer" :-\
I mean come on, I know this is asking alot....lol...but where can I find a "Castle" LockNut? Its for my 71 front end with disc brakes on it? I've got the lock washer already.
thanks! ???
jbassC10 is offline   Reply With Quote
Old 10-30-2013, 11:43 PM   #2
Superdrag67
Re: 71 Spindle Lock Nuts? Where can I find them?
I bought mine at oreilly in the help section. Little kits that cost me like $6 each or something.
Superdrag67 is offline   Reply With Quote
Old 10-31-2013, 12:00 AM   #3
jbassC10
thats the problem...
I've taken two different sets home to see if they fit....? and they haven't.
We've come down to the facts which are; 26mm and standard threads for my 71 front end. and yet they don't care that specific style. :-\ As far as in Arkansas
thanks though! it'll come together somehow!
Old 10-31-2013, 07:23 AM   #4
cdowns
cdowns's Avatar
try NAPA or CARQUEST they normally have better couter help to solve problems
Old 10-31-2013, 10:02 AM   #5
jbassC10
Hey!
I just called NAPA and they ordered one and had one.... so I'll pick it up this afternoon and see if this is the one!
Thanks!
Old 10-31-2013, 10:09 AM   #6
mgchevyparts
mgchevyparts's Avatar
Chevy's are 3/4-20 castle nuts. Rockauto is the easiest way to buy them.
1957 CHEVY 1/2 TON SHORT BED
1940 FORD 1/2 TON SHORT BED
mgchevyparts is offline   Reply With Quote
Old 10-31-2013, 10:14 AM   #7
jbassC10
Awesome!!
Thanks so much!!
Old 10-31-2013, 10:16 AM   #8
Low Elco
Your counter people are idiots. Dorman brand help section part. Good luck!
Low Elco is offline   Reply With Quote
Old 10-31-2013, 12:24 PM   #9
Andy4639
Old member
Andy4639's Avatar
Wink Re: 71 Spindle Lock Nuts? Where can I find them?
Any good nut and bolt or fab shop people will have them are can get them. Fastnel, NAPA any body should have them.
Most of the time it ends up being the person u talk to.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 10-31-2013, 12:31 PM   #10
mgkgmc
mgkgmc's Avatar
Or maybe McMasterCarr might have them too.
1970 GMC 1500 stepside
1972 GMC Jimmy Custom
2004 Chevy Colorado
1989 Swb Silverado
1972 Aj's Stormer
mgkgmc is offline   Reply With Quote
Old 10-31-2013, 01:47 PM   #11
hugger6933
Where do you get 71 spindle nuts? 71 spindle sorry couldn't help it . Jim
hugger6933 is offline   Reply With Quote
Old 10-31-2013, 11:58 PM   #12
WIDESIDE72
WIDESIDE72's Avatar
If all else fails, Industrial bolt supply houses have them but youhave to know what size first. They wont be able to look up anything automotive.
WIDESIDE72 is offline   Reply With Quote
Old 11-01-2013, 09:18 PM   #13
jbassC10
Finally found Success!!!!
Guys thanks so much!!!
Now, time to install the rest of the brake, run brakelines and start the motor!!
#Pumped
Old 11-01-2013, 09:33 PM   #14
Ordering online from Rock Auto is easier,I guess,but not better. For me,it's not that hard and it's 10x better to run to town and pick them up and install them the same day
Old 11-02-2013, 10:34 AM   #15
jbassC10
Yea, I agree. way easier to buy and take back to if it doesn't fit/work out. So theres erie to me sometimes buying online. of course needed at times.
Getting close to rolling it off the stands! The photo is before the restoration.
Thanks man!
Old 12-16-2013, 04:22 PM   #16
Rick.Coleman
So, where did you actually get the spindle nuts and washers. I am striking out also. This should be something easy to get but nothing seems to work for the 71-72 spindles. No one even list a part numer for it.
Rick.Coleman is offline   Reply With Quote
Old 12-17-2013, 11:39 PM   #17
spatz
The truck shop in Orange, Ca. has them in the catalog
spatz is offline   Reply With Quote
Old 12-18-2013, 11:22 AM   #18
jbassC10
Yeah there you go! Try that shop in CA!
Myself, got real stupid and didn't trace the threads looking on the bottom side bolt coming out off the spindle where the crown nut screws over andddd of all things, there's no telling how many of the nuts I tried would have worked? :-(( So after my friend saw the bad rough spot in the threads I cleaned it up and bamb, there she went! And if I'm not mistaking, I went through "Napa" because as you said; some auto part stores don't even carry an item close to it or even able to order a crown nut.
But I believe thinking back through of all the auto part stores I went to "Napa" was the one I found them in!
Good luck!!! Keep me updated on how its going!!
