serious horsepower, 600rwhp, and flip kits...anyone?
I'm looking to lower my truck, and looking at investing into a flip kit. I see most flip kits are just a piece of chanel iron, and didn't look to sturdy.
I was thinking of cutting off a set of spring perches off of an old rear end, and attaching them to the bottom of my rear end, is this nessesary? Will the "u" thing be enough? I will be using a set of cal-trac bars also. Any input is welcome. Thanks David
1985 GMC high seirra, 6.0 ls turbocharged several others..... |
Re: serious horsepower, 600rwhp, and flip kits...anyone?
You should use weld on spring perches if your going to have any serious HP, I have seen the stock spring perches torn off with the use of flip brackets.
John 82 Chevy Silverado 350ci/TH350 ![]() |
My 400hp small block did this with hardly any traction. So what are looking to achieve other than swift death?
I welded on spring perches. Really I think it's the only way to go for any flip ![]()
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
I was thinking the same thing. They didn't look strong at all
I don't know what kind of flip kit that was, who designed it or what it cost, but I think my 4 year old daughter could have designed something better. I'd be pissed off for paying a company to put that on my truck. I have a Western Chassis flip kit on my truck and its built and designed heavy duty. This isn't my tuck in the LINK , but its the same kit I have. You can see the difference in design. I've had it stand up to the stress when I was supercharged with no issues. If the flip kit you get looks like the one Insidious put on his truck return it... that looks like some home cobbled stuff and I cant believe a company would sell that, it just looks unsafe!
http://www.google.com/imgres?start=1...44444274902344
Welcome to my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=574370 |
At the body shop.
500ish hp and cal tracs
Welded on pads from summit. 1.67-1.70 60' all day. ![]()
" That didnt make it any newer " " Dont antique the equipment " |
I've noticed your pics of those trashed flip brackets in various threads. I'm curious if you felt they would be strong enough when you installed them? There's no way I would utilize a bracket like that on a flip kit since there's nothing tying the 'legs' of the bracket together w/the base Like the units Jabes linked in his post). Seems way to flimsy regardless of how thick the material is.
At the body shop.
Proof positive. you get what you pay for!
For the op http://www.summitracing.com/search/p...rd=axle%20pads
" That didnt make it any newer " " Dont antique the equipment " Last edited by KQQL IT; 10-31-2013 at 06:00 PM. Reason: linked |
yeller
Quality flip brackets are much more than a basic channel like that. Look at a Bell Tech or Western Chassis...you will see the difference. I am making 525HP at the flywheel, have Cal Tracs, and have had no issues with my Western Chassis flip kit.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
#10 | |
#11 | |
#12 | |
Here's some more djm screwing for you guys. My buddy got a set just the other week and figures I would share. Imagine this getting in your wheel bearings! ![]() ![]()
#13 |
I bought a pair of perches at my local circle track shop for $8 each. A lot easier than cutting a pair off an axle.
#14 |
i have the western chassis flip kit on my truck. i welded on perches to my buddy's truck. im going to do that method now.
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
#15 | |
![]() Join Date: Oct 2008
Of course, if you can weld then why not go ahead and put on new perches, which is the better solution. FWIW, I had the same type as these from Specialty Retail and they held up to a few hard launches from over 550 ft. lbs. of torque before I pulled them off and replaced with welded perches. I just didn't feel like gambling any longer. |
