10-31-2013, 09:05 AM | #1 |
Question for the board - steering columns..
Is there a difference in splines or shaft diameter between the tilt and non-tilt columns on 67-72 trucks? What about the 73 and up trucks?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
10-31-2013, 09:25 AM | #2 |
2WD Jimmy
Re: Question for the board - steering columns..
If the shafts were different, the wheels would not interchange. I dont know about 73 up though.
10-31-2013, 12:11 PM | #3 |
That's my experience also, just thought I would see if I was missing something.
10-31-2013, 12:39 PM | #4 |
Florida Edition
Hey Rob, In all my poking around I found no difference in shaft dia. Don't know about 73+, maybe the square guys could answer that.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
10-31-2013, 12:59 PM | #5 |
Same as the above guys said. Just did a swap myself from the non-tilt one piece shaft to a two piece tilt and they were the same.
Will 1968 C10 - Project Texa Go 6.0/4L80e 2003 Mitsubishi Lancer Evolution 2002 Ford Excursion 7.3L 2024 Toyota Sienna |
10-31-2013, 01:45 PM | #6 |
Do you mean where the steering wheel goes? that spline is the same from Gm through it whole line from the 60's until the mid 90's or until the use of driver side air bag. Even then as the wheel turned square but they are so ugly they don't count. That is why a lot of people use the wheel off of the chevy/GMC trucks from the late 80's early 90's on their 67-72's, and btw they look great on there. Also so does the Monte Carlo SS 2 spoke split wheel, my fav. Jim
10-31-2013, 01:45 PM | #7 |
no differance in splines either end
11-02-2013, 10:12 AM | #8 |
Thanks all for the info.
