Old 10-31-2013, 09:25 AM   #1
rs74
rs74's Avatar
Do 6.2 diesels take a different fan shroud?
The one on my 85 K30 is busted and it looks completely different from any of my other trucks.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 10-31-2013, 10:15 AM   #2
Idaho64GMC
Re: Do 6.2 diesels take a different fan shroud?
I think they have a bigger radiator so it wouldn't surprise me if the shroud is different, Not sure where you'd find a replacement.
Idaho64GMC is offline   Reply With Quote
Old 10-31-2013, 12:12 PM   #3
86c20
86c20's Avatar
i think they are the same as a bb. but i maybe wrong
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph
1985 k30 "the ice cream truck from hell" no rust az truck
197-8??? c30 "ramp truck" 454
1978 monte carlo 350 350th with 2.73 gears. no rust. sc car
86c20 is offline   Reply With Quote
Old 10-31-2013, 01:27 PM   #4
rs74
rs74's Avatar
Mine are different between my 454 84 K30 and my Diesel 85 K30. Pics are not the greatest but they are different. The first is the big block truck and the rest are of the diesel. I am going to have to take some measurements. I might have an extra shroud to try. The one on the 6.2 is busted at the top from the fan blade and it is a little more flimsy than the other.
Roy
1987 R10 shortie
Old 10-31-2013, 01:47 PM   #5
Edahall
Get a long piece of wide aluminum flat bar to bend to the shape of the fan shroud. Then bolt it to the outside perimeter so that it covers the defective spot.
1990 ¾ ton 4x4 Chevy Suburban
-Cummins Diesel - 12 valve - factory rebuilt
-6 speed bullet proof manual transmission - NV5600
-Gear Vendors Overdrive - HX35 Holset Turbo
-NP205 iron transfer case
-3.73 gears -2" Lift
Edahall is offline   Reply With Quote
Old 10-31-2013, 04:42 PM   #6
83GMCK2500
Yeah the diesel's have a wider radiator, look at the top of the core support and you'll see the second set of bolt holes for the driver's side radiator hold-down bracket. The passenger side is static.
Someone IS parting out a super clean diesel truck in out classifieds right now...just saying, not me but I saw it.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 10-31-2013, 05:56 PM   #7
mrolds88
Another place to look is the military CUCV's.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 10-31-2013, 07:16 PM   #8
rs74
rs74's Avatar
Yeah you are right. Thanks. I had forgot about it.
Roy
1987 R10 shortie
