![]() Join Date: Mar 2012
wiper pump info
Has anybody used this AC Delco wiper pump
P/N 22071780, I bought from Amazon after researching it on Rock auto, I thought it would be a be quality option because it is a AC Delco product, but I see no way it can bolt up or be hooked up to the existing set up , Unless i am doing something wrong under the dash??? any suggestions ![]()
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
Re: wiper pump info
I bought a tank and pump from a late-model truck at the salvage yard. Here is a link that shows how to wire it up to your existing switch.
http://67-72chevytrucks.com/vboard/s...d.php?t=587726
Willie Swamp Angel Truckers '72 C10 Highlander ![]() People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. ![]() |
