Old 10-31-2013, 01:06 PM   #1
61K10
61K10's Avatar
gas tank straps
I see two different after market straps for sale, one with holes on both ends (for the bolts) and the other with the front bolt pad and the rear is just folded over. do you drill the strap for the rear bolt? of course one is cheaper than the other. might just make my own.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 10-31-2013, 01:24 PM   #2
kieth
kieth's Avatar
Re: gas tank straps
do not know which straps you speak of but I have seen straps that have a provision for a bolt in one end and a slot where a T bolt fits to allow it to attach on the other end. In our case we used straps that had holes in each end, then modified one end to bolt to a crossmember which we drilled holes in. Kieth
using the std straps with holes,
http://kieth.smugmug.com/Trucks/66-G...0605&k=WzzVJXB
the rear of the tank straps :
http://kieth.smugmug.com/Trucks/66-G...0612&k=GHLg7T2
Kieth
kieth is offline   Reply With Quote
Old 10-31-2013, 01:41 PM   #3
61K10
61K10's Avatar
Re: gas tank straps
thanks Kieth for the info. I guess i should of said straps for the stock in the cab tank. might go to the rear tank later and will use your info.
1961 chevy K10
Old 10-31-2013, 03:44 PM   #4
1963c-10
1963c-10's Avatar
Re: gas tank straps
61K10...I have an oem pare sitting in a box here if you need a set. Boxed them for someone else and they decided they didn't need them. Just cover the flight.....
Came out of my 61 c-10 parts truck
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 10-31-2013, 03:57 PM   #5
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: gas tank straps
I think the 60-62 straps are a little different than the 63-66
66 C20 Service Truck:
Old 10-31-2013, 04:03 PM   #6
LostMy65
LostMy65's Avatar
Re: gas tank straps
If you look at the back of the cab, about halfway up the back wall, there are brackets that the folded part of the strap slips in. The cab is a 66
Old 10-31-2013, 05:30 PM   #7
WhippinSaw
WhippinSaw's Avatar
Re: gas tank straps
good pictures of both gas tank straps here (best use of windows paint that I have ever seen)http://67-72chevytrucks.com/vboard/s...highlight=tank
WhippinSaw is offline   Reply With Quote
Old 11-01-2013, 03:08 PM   #8
61K10
61K10's Avatar
Re: gas tank straps
so they must have changed in 63 or 64? here is a pic of mine which bolt down by the floor in back, not like the tabs on the back wall.
1961 chevy K10
Old 11-01-2013, 03:13 PM   #9
1963c-10
1963c-10's Avatar
Re: gas tank straps
That's the set I have boxed up if you need them. They came out of the 61 in my front yard
Old 11-01-2013, 04:07 PM   #10
61K10
61K10's Avatar
Re: gas tank straps
thanks 63c-10 for the offer. i can probably fix the one i have that is broke. will pm you if i need them. so what kind are in your 63?
1961 chevy K10
Old 11-01-2013, 05:34 PM   #11
WhippinSaw
WhippinSaw's Avatar
Re: gas tank straps
61K10
My 63 are bolt down like yours, maybe changed in 64
Old 11-01-2013, 06:13 PM   #12
1963c-10
1963c-10's Avatar
Re: gas tank straps
The same as the 61. No problem....they are just taking up space here. If you need them, cover shipping and they are yours.
