Old 10-31-2013, 01:22 PM   #1
K20chevy
K20chevy's Avatar
18" or 20" 8 lug OEM looking steel wheels?
Hi,
has anyone heard of 18" or 20" 8lug steel wheels that look like the old 16" OEM wheels? And possibly even work with the stock old hub caps? Iīm trying to keep the vintage theme as much as possible, but need larger wheels due to my big brakes.
Iīve seen Centerline Smoothies converted to accep the OEM hub caps and it looks nice. Iīm just concerned, that if I really use the truck and the brakes, that the fully closed wheel might cause the brakes to overheat. Some little slots like the OEM steelies had would be enough, just a little to get air in.
I tried everything online, but couldnīt find anything! The new OEM steel wheels look too modern for my taste. (and the 17" stock Dodge steel wheel doesnīt fit, already tried that).
78 Chevy K20 Custom Deluxe, build: http://67-72chevytrucks.com/vboard/s...d.php?t=612104
68 Chevy K20 Panel truck, build: http://67-72chevytrucks.com/vboard/s...41#post7263441
K20chevy is offline   Reply With Quote
Old 10-31-2013, 05:42 PM   #2
BONUSCAB
Re: 18" or 20" 8 lug OEM looking steel wheels?
19.5's. Home made.
Few things in life will make you look stupider than putting a dollar sign after a number.
BONUSCAB is offline   Reply With Quote
Old 10-31-2013, 06:02 PM   #3
K20chevy
K20chevy's Avatar
Originally Posted by BONUSCAB View Post
19.5's. Home made.
Thanks for your reply! The half sizes wonīt work for me though as I need off road tires. So 18" and 20" are the only sizes working. Width would have to be 8.5 to 9".
How did you mount the OEM hub caps?
Old 11-01-2013, 04:50 PM   #4
BONUSCAB
The wheels are (Dodge) 16" wheel centers welded to a steel ring welded to a 19.5 dually wheel with the center cut out of it. Everything under, and arounf, the hub cap is a normal Dodge wheel and the Chevy hub cap pops on just the same. Dodge uses a bigger hub to pilot off of than GM, so to the wheels on and centered takes a little attention to detail.
Old 11-07-2013, 11:28 AM   #5
K20chevy
K20chevy's Avatar
Thanks for the info. I might have to take an aluminum wheel that looks like something offered back in the days and maybe craft the hub caps on there somehow.... Maybe thatīll look half way OEM then.
Old 10-31-2013, 06:03 PM   #6
KQQL IT
At the body shop.
KQQL IT's Avatar
Stockton wheel may could help.
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 11-01-2013, 01:33 AM   #7
K20chevy
K20chevy's Avatar
I already called them and they could make a 18"/20" steel wheel, but not looking like the old factory rim. The guy said it would mook like the spoke wheels or the round hole wheels. And for that look, I can get some light weight forged weld racing wheels as well.
I was really hoping someone would make a completely stock or OEM looking wheels, just larger AND that accepts the stock hub cap.
