![]() Join Date: Dec 2012
Were there any 4 bolt mains other than 350s?
Just curious. Were small block Chevys ever released from the factory in our trucks, in any displacement other than 350 C.I.D.?
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
![]() Join Date: Mar 2003
Re: Were there any 4 bolt mains other than 350s?
There was a 4 bolt main 400 cubic inch and I think the 302 in 68 was a 4 bolt
![]() Join Date: Sep 2005
there was a 4 bolt 327 but it was used in the old massey ferguson tractors
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
#4 | |
302/327/350 blocks (4" bore, 2.3" or 2.45" mains), and 400 blocks (4.126", 2.65" mains). In 1968 the main bearing saddles were increased in size from 2.3" to 2.45". CID Year Bore Main Cap 262 1975 3.671 2 bolt ONLY 267 1979 - 81 3.500 2 bolt ONLY 305 1976 - 96 3.736 2 bolt ONLY 307 1968 - 73 3.875 2 bolt ONLY 327 1968-69 4.001 (2.3" main) 2 bolt 350 1968-88 4.001 (2.3" main) 2 bolt 265 1994 4.001 (2.45" main) 2 bolt 302 1968-69 4.001 (2.45" main) 4 bolt 350 1968-96 4.001 (2.45" main) 4 bolt 400 1970-72 4.126 (2.65" main) 4 bolt 400 1973-80 4.126 (2.65" main) 2 bolt Notes: 2 bolt ONLY means just that,. otherwise 2 or 4 bolt can mean either design... interpret that to mean that there "Could" be a 4 bolt 327 built in 68-69 for the Camaro as was the 302 from those same years which went into the Z28. There are no records from the GM Historical center showing what went into the C-10's other than the 2 bolt 327's and the 4 bolt 400's but those records might be incomplete or inaccurate. |
Great Info! Thank you. I'd only wonderded as I bought a "350" used.
I didn't know if they did 307's in 4 bolt. I pulled the pan on this one to look at the bearings change the oil pump coupler, secure the pick up and seal some leaks. I do know it's 4 bolt but didn't measure the bore or stroke. Thank you again.
that's what's in our really old combine would be a fun one to build the hell out of.
1969 Chevy C10 2wd stepside longbox |
There are definitely 4-bolt 327s. The '68 truck engine I have is an 010 casting,which is a 4-bolt large journal. IIRC,it's the same block as the '68 Camaro SS350 as well as the Z/28 302. High nickle and steel crank,too!
#8 | |
I don't know what kind of internals it had, but I would bet that it had forged pistons and crankshaft.
"Negative people always seem to have a problem for every solution" |
![]() Join Date: Jul 2013
The 67-68 MO302's were 2 bolt Z/28 only. The 69 DZ302 is 4 bolt large journal Z/28 only. Some 327's were 4 bolt, but late 67-68 large journal. Some 70-72 400's are 4 bolt. Then 350's could be either depending the application.
To be honest GM did alot a weird things back in the late 60 early 70's. The strikes in 68,69,70 brought about a lot of parts swapping. For one, Tonawanda engine plant was a big block plant, yet in 69-70 they built some small blocks.
Mark Jesus is the Way! 2003 2500HD CCLB Duramax/Ali (Clifford) 2014 2SS/RS black on black Camaro (Betty) 2006 Pontiac SOLSTICE silver/black (Lula-Bell) 1970 C/10 Short Wide (Peggy) 1964 C/10 Short Step (Hambone) RIP Jimmy Hamilton Thank you for the trucks |
