Old 10-31-2013, 04:55 PM   #1
Andrewb83
Andrewb83's Avatar
Need help
Hey trying to take apart part of my steering system but not sure what the part is called it connects to the pitman arm. The three bolts are off but can't get the washers off. I have been bashing it with a mini sledge and it won't budge at all. Maybe a torch? Thanks for the help.
Andrewb83 is offline   Reply With Quote
Old 10-31-2013, 07:44 PM   #2
cadillac_al
Re: Need help
"even a rock will crumble
if you smack it night and day"
Aerosmith
I have never had the pleasure of removing one of those steering arms but I would expect a lot of hitting, possibly at least an hours worth. An air hammer might help too. After an hour of smacking it and air hammering, I would probably try the air chisel and try to separate it. I had a balljoint once that I had to hit for about an hour. I said "See, if I would have quit pounding at half an hour I would have failed" That's when I start singin' Aerosmith and keep smackin' it.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 10-31-2013, 10:11 PM   #3
Andrewb83
Andrewb83's Avatar
Re: Need help
Aww geez if it's that hard ill just paint it is. Thanks Cadillac al
Old 11-02-2013, 09:18 AM   #4
killerpanel
Re: Need help
they can be a real pain to get off. I have had the pleasure of changing several of them. Every time i lifted a truck. Usually takes a rosebud torch. Heat them up and beat the arm with a hammer until the wedges pop.It takes a bit to get the conical wedges out. but once they pop, they slide off. Then just beat the arm until its off
killerpanel is offline   Reply With Quote
Old 11-07-2013, 01:29 AM   #5
swamp rat
swamp rat's Avatar
Re: Need help
Its called a steering arm, go into my build thread and scroll thru till you find when i was dealing with mine.. lots of info there.. but i did mine without a rose bud (wish i had one)
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
